Been there, done that!
I just bought a 95 Yukon 4wd w/350 and am having problems. The truck won't start. All lights and radio work but there is no cranking or clicking sound from the engine unless the ac is turned on. A friend hooked up a remote ignition to the starter and we could hear the starter spinning. We determined the starter was the problem and replaced it with a used one from a junk yard. It worked great for 2 days but now it is not starting again. The battery checked out fine at AutoZone. Any suggestions on this or where online I can find some help? Thanks.
These use a double terminal on the positive side of the battery. Double check the INSIDE terminal of the connection, its usually the cause of starting problems on the newer trucks. If your still having trouble.. grab a new/reman starter (good quality) and install it.
I have a feeling its just a connection at the battery though.... you would have unhooked the cable(s) to replace the starter correct? Double check those cables
| Bookmarks |
