Old 01-20-2007, 04:48 PM   #1
RetroSBK
Panhard bar and Shortened bed????
Had the truck up on the rack this am, damn its good to be back drivin her after 4 months apart!
Bear with me, and I am still learnign about our trucks!
I noticed that the panhard bar in my truck is non adjustable. has an upwards angle tho. Rear of the truck is lowered 6inches on springs, was going to throw the bags in today, and realized that I dont have an adjustable panhard bar, so Im a bit concerened about using the bags with what may be a std bar.
Does anyone have a measurement end to end or center to center on the stock bar so I can compare?
Secondly, while deciding that I really need to remove the frame and blast and powdercoat it, I noticed that behind the cab, there is a section that looks welded. There is a slip style brace welded to half the frame and has three bolts on each half. total of six bolts, in two small triangles.
The frame was either fully welded and the brace bolted inside, or thats just how they are stock. any ideas?
If it was in fact shortened, Im pullin her apart and throwing the chassis on a jig and making sure its square, then of course need to powdercoat and freshen it all up!
lol
Thanks in advance guys!!!
Will
1970 C10, shortened long bed, Alum Headed full roller 383 (with Victor, 750DP, stainless rockers, behive springs, CNC ported heads) TCI SSF 700R4, 4.10 Posi, Bagged on C-Notch and 2.5 spindles. Air Cond, black out tint, satin black paint, custom interior, rolling low and not so slow...
RetroSBK is offline   Reply With Quote
Old 01-20-2007, 05:33 PM   #2
sick69
sick69's Avatar
Re: Panhard bar and Shortened bed????
its kinda hard to say with out seeing it but I don't know of any spots that are welded on the factory frame. kinda sounds like its been shortened or repaired at some point.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 01-20-2007, 10:10 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
these trucks have full one piece frames so it most likely has been shortend and yes you should put it on a jig and make sures its square and then weld it up good and solid and check the rest of the frame while youre at it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-20-2007, 11:22 PM   #4
bad_turbo
turbo enthusiast
bad_turbo's Avatar
pics would be nice! Camarillo is just over the grade from me, good to have another member soo close!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 01-21-2007, 12:10 AM   #5
RetroSBK
Yeah, I know.. Should have taken sum on the lift...
Ill be at the shop for a bit tomorrow, ill take some and post them!
Will
