Old 01-20-2007, 06:04 PM   #1
1969k10stepside
Lightbulb How I removed them frame rivets
I needed to remove the rivets holding on the spring hangers on my swb 4x4.
I started a thread asking how to do it and mixed up all the anwsers.I gathered up a chisel,punch,grinder,hammer,and my propane cutting torch.I first grinded the rivet heads off.I then used the punch to loosen the rivets some.I used the chisel and pried between the frame and spring hanger knocking it loose with the hammer.I then heated up the area around the rivet with the torch to loosen up the rivet and then hit it out using the hammer and punch.I averaged about 2-3 minutes per rivet and had to remove 6 per side.Hopefully someone can make since of this and use it to their advantage.
Dustin
1969k10stepside is offline   Reply With Quote
Old 01-20-2007, 07:38 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: How I removed them frame rivets
don't heat the rivit, heat the area areound the rivit. You need to expand the metal, when you heat the rivit it's self, you are expanding the rivit and making it tighter.
Old 01-20-2007, 08:09 PM   #3
cstm68
cstm68's Avatar
i just removed some myself about 20 min ago. i tool a cut off wheel and cut an x through the top of the rivit (you could use a saw) then i took an air chisel and broke off the head and popped the rest out with a hammer and metal rod
cstm68 is offline   Reply With Quote
Old 01-20-2007, 08:16 PM   #4
1969k10stepside
Andy,thats what I meant,I just cant turn words into type letters sometimes Im gonna edit the post
