i love summertime
Stupid Question
i hear a lot of talk about "x", "y" and "H" pipes, can someone tell me what the diff is between them? and what kinda advantages they have over one another? this might seem like a stupid question but im still fairly new to some stuff..thanks guys
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
its all about the +6 inches
A Y pipe connects the 2 pipes coming off the 2 manifolds, and combines the 2 into one for a single exhaust system.
An H pipe is a small pipe connecting 2 seperate halves of a true daul exhaust. An X pipe does the same as the H pipe, but it is 2 pipes installed and forms an X as viewed from underneath. As for advantages, the Y pipe makes it cheaper to run exhaist in low power aplications, or when required by federal law for catilitic converters (whole new thread) The H pipe ballances the exhaust pressure freeing up a few pounds of torque, while making the exhaust tone a little mellower. The X pipe does the same as the H pipe, but does quite a better job of it. (I've never seen dyno testing on X pipes, but I'm sure it has been done) |
Another note to longhorns explanation is the location of the H and X pipes. The best location to have a crossover is where the pipes get the hottest, However that may not be the best place as for as transmision ,clearance and other factors.
The only way I know for sure to locate the hot spot is to spray paint down a hot exaust and note where it burns it the most. Maybe someone else has an idea that is better and is less messy.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air. 68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles 68 anniversary no engine long wheel base 400 auto FOR SALE 68 Chevy fleet side long wheel base complete parts truck. |
That is the best way I have heard too.
i love summertime
thanks
thanks for the info guys...kinda figured that but it was sorta a grey area before..now its black and white
#6 | |
'Heavy Metal' Redefined.
An X pipe changes the exhaust tone to a slightly higher pitch I've been told. The gasses reach a high velosity as they equalize than they do in an H pipe. The high velosity is supposed to increase torque a bit. I don't have dyno numbers or much experience either. Just learning too.
1967 C10 LWB stepside, 250 engine, GM HEI, aftermarket A/C., Clifford Performance intake, Stovebolt split headers, Carter AFB 500, X-pipe & Dynomax Super Turbos, 1 piece custom driveshaft, cyprus bed wood & stainless bed strips. Starkville, Mississippi | My Truck Page |
68cst_ss490
I've heard that an x pipe is for higher rpm applications, and a h pipe is fine for the street, you only need an x pipe if you have over 600hp. Most peoople say the h pipe is the way to go
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
#8 | |
