Old 01-20-2007, 10:46 PM   #1
MXmaniac
MXmaniac's Avatar
Throttle linkage on a '69 C-20, 292 I6
Can anybody show me a picture of the throttle linkage on a 67-72 with a 6 cylinder? The previous owner had problems with his feet and modified the linkage so he wouldn't have to move the pedal as far. Now I have no idea what parts are missing or have been modified. Anybody have a picture?
MXmaniac is offline   Reply With Quote
Old 01-21-2007, 01:23 AM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Throttle linkage on a '69 C-20, 292 I6
i have a 69 c20 with a 350 but think the linkage would be the same.
it's just a long rod ..i put some bends in mine to shorten the throw as well
rage'nrat638 is offline   Reply With Quote
Old 01-21-2007, 07:10 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
Stock [68] 292s with the rod-type throttle linkage had a long rod from the accelerator rod at the firewall to a bellcrank that pivoted thru a 1/4" 'tunnel' across the exhaust manifold behind the carb mounting. A smaller rod went from the top [?] of the bellcrank to the throttle linkage on the carb.
When I went to a 4bbl carb and Offy manifold, I had to fabricate all-over again... After 20 years or so, I found it better to convert to cable. But it was not an easy bolt-on swap. I don't have the stock linkage anymore.
Old 01-21-2007, 09:26 PM   #4
MXmaniac
MXmaniac's Avatar
Thanks guys, that helps a lot. Now I get to fab a linkage... .
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
Old 01-21-2007, 09:41 PM   #5
cruiserman
There's a picture of the bracket in the chevy shop manual. Unobtanium.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
