What would I need?
Since I basically have the entire front clip off of the truck I was thinking that I would pull the motor to do a few things. I have a new flex plate & motor mounts for it as well and would like to clean up the engine bay as well as the firewall. I dont have anyone around to help me so I was thinking about renting a cherry picker and going to town. Is there anything else that I might need?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Chief Honcho In Charge
Re: What would I need?
Possible an engine stand...to bolt it to to work on it.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
Couldnt it stay on the cherry picker? Its only going to be out of the truck for the amount of time it takes to change the flexplate, clean the engine bay, and repaint the engine.
Count on those tasks taking twice as long as you think. Something will break, or you will find a couple other things that need to be fixed.
I would get a couple blocks and an old tire and set the engine on that, I wouldn't release all of the weight, but use it as a safety in case something happens and the cherry picker drops them.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Why not just spend a little and buy a actual engine lift,never know when you will need it again.I use mine alot
I thought about buying one but I have no place to put one. Barely have enough room for the tools
67-72 parts finder
well you can't change the flywheel on the cherry picker or an engine stand you'll need to drop it down on a tire or some blocks or something to keep it still might set it on a tire to hold it in place but keep some tension on it so it won't turn over those flywheel bolts can be quite tricky
![]() ![]() 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
I'm a poor spectator
You don't want to work on the engine while it's hanging in the air by a cherry picker. You'll have a hell of a time trying to torque anything down to your engine or take anything off because it will just keep moving around on you. At the very least set it on a tire. Oh and in case you don't have some, grab some 2 inch 3/8's bolts and some washers to attach the chain to the block. If you're like me then once that engine comes out you're gonna go crazy and want to do all kinds of other stuff so I hope you have your mind made up that you're gonna do just what you say and nothing else cuz you might be opening up a can of worms.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
I can get a couple of tires. I did forget about the swinging around piece. Now I gotta find a rental place around here that rents the cherry pickers. Thanks for all the tips.
