Grey wire on tilt column
Where does the grey wire on a tilt column get plugged into?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Grey wire on tilt column
someone correct me if i am wrong but i think thats the wire that lights up the shift indacator and would plug into the dash light ear on the fuse box..
if your converting to tilt find a extra buld to plug in where the optic cable used to pug in on the back of the dash... ![]() |
Mark that sounds right. Where do I plug it into at the fuse box since mine is a 68?
well mine has a spot marked dash.. i have never seen a 68 but a test light would work for finding a wire like from the heater controll that lights it up. if theres not something on the fuse box...
heres a picture of my fuse..i can't even tell what i have..? and a extra picture Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
![]() Join Date: Jun 2006
My buddy and I just finished rebuilding a 72 truck tilt column to go in my 68.
I needed a new turn signal switch which came with the bulb holder and the gray wire snapped into the connector end comming off the t/s switch. That end would normally hook to a factory connector I think. The factory harness in your truck should be a horseshoe/half circle shape. Anyway it goes, the gray wire should just hook up to any terminal or lead with 12volts (key on) or I will prob hook mine up to power on with the park/headlamps on.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
Ok now for my dumb question
There should be one labeled ign. Or you can use a test light to find out.
It's a catastrophic success.
![]() Join Date: Jan 2003
You can hook it to the light that feed the heater control.
