Alright Alright Alright
adjusting idle screws on a qjet
the weather is very cold here and my truck runs really bad at idle. i unscrewed the idle mixture screws about half a turn and it ran good for a while and then did the same thing after sitting a day. what do yall think? which way do i turn the screw the screws to get more fuel at idle....if thats the right thing to do?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
67-72 parts finder
Re: adjusting idle screws on a qjet
be a lot cooler if you got rid of that qjet LOL j/k
![]() ![]() 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
![]() Join Date: Dec 2006
Have you tried adjusting the choke? That sounds like the issue to me.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
well, it is a divorced choke and it doesnt work with my rpm intake...so i dont have one. however, the choke is completely open. the truck will run like crap for the first 10 min of driving even with the heater blowing hot.
#5 | |
Semi-Senior Member
The ONLY way you normally adjust the mixture screws is after the engine is COMPLETELY warmed up. Start by seating each one and opening the same amount (do this engine off), maybe 3 1/2 turns. Start the engine and open each screw 1/2 turn. Listen if the engine speeds up. Keep doing that until the RPM's don't increase. Now turn the screws in 1/2 turn at a time until the rpm's just start to fall. Open each screw another 1/2 and your done. You could open another 1/2 since your choke isn't working...might help a little. Now when the engine cools off again, it's gonna run like crap until it's warm again. Live with it or fix the choke. BTW, the farther from stock your engine is, the worse it will run when cold.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab Last edited by 68speedalert; 01-21-2007 at 10:19 AM. |
Sierra Grande Club
Or you can use the above method using a vacuum gauge and adjust until you get max vacuum.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
My Father in-law did my carb yesterday (Holly
![]() Kevin LFD Inc. |
Parts and more parts
The idle mixture screws are just that (they provide a stable air/fuel mixture for the idle), they do not provide an idle speed. The choke governs the need to add more fuel to control the idle during a cold start. This is designed to make the motor run rich at that time so that it will overcome the cold temps. You could adjust your normal idle screw up to hold the motor at a higher idle speed, BUT it would idle like that at all times (not good), so unless you fix your choke you will always have cold start problems. Since you are running a carb that is not attached to either the intake for control, or a hand choke, or an electrical choke, the problem continues. I would look at upgrading to either an electrical connection and install the electric choke kit or put a hand control on it. I imagine that Edelbrock still has the conversion kits for that, since it is a performer Q-jet.
67-72 parts finder
edelbrock does make a kit to convert the divorced style choke to an electric choke i'm wanting to say as a matter of fact i think mark aka rage n rat was talkin about that the other day might wanna ask him he probably has a part number i'd say fix the choke then set the carb
village idiot
only thing an old Q jet is fit for is a doorstop
Semi-Senior Member
Only for those not smart enough to fix em......
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
I suppose automatic transmissions, and disk brakes are junk, too....
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
#13 |
Semi-Senior Member
#14 |
Old Time Rodder
Mine works great and get pretty good mileage.
79 GMC SWB Lowrider Stepside [81 cab] that thinks it a Chevy (since 6/1980) Replacement cab had A/C which now works, made a real truck out of it 84 MC 305 350TH 3.08 4 wheel disc finally My daily driver again |
#15 |
bow down to the q jet, once you figure them out, they are the best carb ever made for daily driving and 450hp and under motors
#16 |
heres the edelbrock convertion kit and a few pictures
![]() i will get here sooner or later..i am slow in my old age ![]() Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
#17 |
will i need to find a carb that has the heated choke to use the conversion choke? my carb has nothing on that side of the carb and i dont see anywhere to mount one. as for the qjet, i think that general motors is the best and i think that they only go with the best parts.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies Last edited by crm318; 01-23-2007 at 01:39 AM. |
#18 |
Semi-Senior Member
You are correct, your qjet must have the heated choke for that kit to work. You still have the correct still carb for your truck. Look for one from a 70's model full-size GM car or late 70's GM truck.
The bigger the engine the better. You've got a good enough engine that a larger qjet would help it run better. You could get a manual choke conversion for your carb, but they rarely work very good.
#19 |
manual chokes work great as long as the person running it knows what they are doing
#20 | |
Semi-Senior Member
OEM manual chokes always work good, conversions are not as good; brackets are never strong enough for one thing.
#21 |
How about a pic of your carb, showing the choke area and let's see what is up.
#22 |
i would but im the only guy in the world that doesnt have a digital camera. however. i do remember when i got it from the parts store, it was for a 72 chevy. there are no areas on the passenger side of the carb that would be able to mount a heated choke. its only cold for a month or so here in texas and im thinking about buying junkyard carb with the proper set up and rebuilding it before next winter.
#23 |
It is now that I would start looking at installing a manual choke cable.
#24 |
Eh quadrajunk..... i suggest this www.barrygrant.com
#25 | |
Semi-Senior Member
