Old 01-21-2007, 12:39 PM   #1
FLOutlander
Removing Body From Frame
I've decided that it would be easier to work on my truck if the body were removed from the frame. That will allow easier access to the various front suspension components, and I can spray paint the frame to prevent rust. Anyhow, I'd like some input as to how to go about lifting the body off the frame. I don't have a lift or anything, so what are some shadetree-mechanic ways that have proven effective for you?
I have tow straps, chains, and come-alongs.
FLOutlander is offline   Reply With Quote
Old 01-21-2007, 01:42 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Removing Body From Frame
I used my friends to help with this task. Took three of us for the bed, and three of us (should have been four) for the cab.
bigblock73 is offline   Reply With Quote
Old 01-21-2007, 03:08 PM   #3
Joe67
67 is sold
There are a few threads on this in the 67-72 section.
I have removed and replaced my '67 Cab a few times by myself. I use a Cherry picker, a 2x6 places through the door openings and a 2.5" rachet tie down strap. I use the cherry picker from the top of the roof (outside).
Some have rigged a brace that goes inisde the cab and you use the cherry picker from the inside.
Both methods work great
Of course, if you have 2-3 buddies, that is the best route for a bare cab
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 01-22-2007, 01:11 AM   #4
cobinder
Everything is work in progress
cobinder's Avatar
Or ya could try this method.
http://67-72chevytrucks.com/vboard/s...d.php?t=113397
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
