Flasher Relay
Does ayone know if you have to have the "special" flasher relay if u have LED tail lights i just have the bulbs from autozone that plug into stock location but when i was looking at the LED Panels they are making now with a full panel of LEDsand on the page it was on said needed a special flasher if using ANY LEDs can anyone confirm this?
Redneck Rampage 1972 Chevrolet C-10 LWB 350 1972 Chevrolet K-20 LWB 502 LiFtEd |
its all about the +6 inches
Re: Flasher Relay
First of all, You'll be disapointed with the lights you got. Personally, I'd never use them in back. They'll light up a small section of the tail light real bright, and the rest will be unlit.
However, to answer your Q, 99% of the time, you do need an alectronic flasher. NAPA has one that I think is less than 10 bucks. Be sure to ask for an electronic one. Last edited by Longhorn Man; 01-21-2007 at 02:22 PM. |
#3 | |
Re: Flasher Relay
Re: Flasher Relay
if they are flashing now, then no need.
Re: Flasher Relay
yes they flash fine thank you for the info
Re: Flasher Relay
yep, you're good then.
Most LEDs have such a low amperage draw, the mechanical flasher doesn't sense the load, and refuses to blink... it thinks there's a light burned out. Your 1157 leds probably have something inside to increase the laod. wEven an LED with 50 diodes will oporate on milliamps instead of multiple amps. |
Eat My Rust
Re: Flasher Relay
Older Cadillacs did similar things, they'd blink like crazy thinking the bulb was burned. I believe you can add resisters to fix both issues if I remember right.
