NOT REALLY BANNED!
![]() Join Date: Jul 2004
Inner Fender to fender bolts
How do you get them out? They're just spinning around for me?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
Re: Inner Fender to fender bolts
grind the heads off..
![]() thats the easy way ![]() |
NOT REALLY BANNED!
No air tools or grinder. ![]()
just put a vise grips on the nuts and hold it then either tighten the bolt till it twists off or back the bolts out.
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
NOT REALLY BANNED!
Cant reach 'em.
i just did this last week but i'm replacing my inner fenders so the saw saw was a easy job about 2min. a side.
is the fender on or off the truck?
i could seem to reach them even when they were on the truck, but then again im a scrawny 18 year old so that may be the difference ![]() |
man that means they're rusted bad and your screwed.
i would spray penatrating lube on the nuts. but really i would use my grinder but you can't. |
NOT REALLY BANNED!
Cant I just unbolt the inner fender and take it off with the fender? The only bad thing is, the bottom bolt on the fender is spinning too.
#11 | |||
Union Electrician
Yes you should be able to get it off with the fender
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
Lets see no air tools or grinder time to get out the hack saw on those bolts.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
#13 |
NOT REALLY BANNED!
The good thing is, I'm doing a 68 Frontend conversion with all new sheetmetal from goodmark and lmc, so the front sheetmetal is prettymuch disposible, I just didnt want to have a super pain in the ass to get it off.
#14 |
what don't you just pull what whole front clip on in once piece then? 14 bolts and the whole thing's off. chris
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
#15 | |
NOT REALLY BANNED!
The bottom rear bolt on both fenders are stuck to the cab... They spin freely, wont budge. Everything is gone but the fenders.
#16 |
id just see if i could borrow a grinder from a friend, just my $.02
#17 |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
You may not be looking at the right bolt for the attachement of the fender to the cab. There is one bolt that attaches the fender to the inner fender with one of those clippy deals that commonly breaks and spins. This bolt points from the ground to the sky and takes a 1/2" socket. The bolt that you are interested in points to your neighbors and does not involve one of those nuts with the clips that break. I believe that it is a 9/16" socket. There is really no way for it to just spin.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" Last edited by breeh; 01-22-2007 at 03:16 AM. |
#18 |
67-72 Addict!
Before you install your new sheet metal, invest in some new hardware so it will be easier next time. My 2 cents
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#19 |
Hack saw blade. I take the blade and slide it between the fender and inner fender and cut it off. Takes time but works. I have had to do this at junk yards and when my compresor was down. By the way go to big lots and buy a huge pack of hack saw blades for like 5 bucks. Has 15 in each pack. Cause trust me you are going to destroy a few.
#20 |
~Rest In Peace~
whats wrong with your lazerbeam eyes to melt metal dude!!!
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#21 |
Who sells the the clips? Brothers list something called "J" nuts, are those what I need?
I am doing a '67 front end swap and my old clip broke coming off and the ones on '67 fenders are long gone.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 09-07-2008 at 01:58 AM. |
#22 |
I am a Referee of life.
Ford Assasin,this thread is old but I can tell you that most if not all of the BB vendors carry a complete front clip bolt kit.If you can't find one check with board member/vendor Tim Christian.I know he carries them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#23 | |
Sweet, thanks!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
