01-21-2007, 08:49 PM | #1 |
finally started
Well I've been lurking around this site for a bit silently reading and learning for the most part,collecting the occasional part.( Great site by the way). I bought a 68 Lwb K20 about a year and a half ago. 350 4 on the floor and 4.56 gears. hadn't done much since then other than minor maint. I cleared out my garage on sat and today started to rip into it. Removed trailer hitch, lights and harness, and unbolted the bed. wasn't sure where to start, but I came into a 14b rear so going to rebuild from the back to the front. Felt so good to finally start after seeing so many motivating build threads Also planing on pulling the bed completely apart, I tried to remove some of the carriage bolts but the just spin, I know you guys know a sweet trick for getting these out.
Thanks Ken Ah, and what is a thread with out pics! |
01-21-2007, 08:56 PM | #2 |
Re: finally started
Nice looking 68. It looks mean and aggresive. Have fun with it.
Respectfully
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
01-21-2007, 09:09 PM | #3 |
In Memoriam...
Re: finally started
That truck looks like a great way to start yer project. Love the wheels. Also, I think the LWB's look best as a lifted 4x4. Good luck with it, and keep posting pics.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
01-21-2007, 09:24 PM | #4 |
Farm Truck
Re: finally started
Don't try to loosen them, it will take forever. Tighten them and they'll break. Alot easier.
01-21-2007, 09:33 PM | #5 |
To The Levy
Re: finally started
welcome parkerkl. first of all, you got the right Idea, mingle for a while , get your toes wet and show off your sweet truck, I love those trucks,especially the 67-68 grille , let alone a four wheel drive with heavy duty 3/4 ton running gear. nice project atleast somthing that will keep ya busy, the fun never ends especially when you do it yourself and it works or looks good, as far as your bed bolts , what usually happens is that the carriage bolts have a square head and the nut gets sorted rusted on and when trying to remove the square part just spins in the bed (as if you havent already figured out)
I would try the tightening method , but if that doesnt work , what about a cut off saw if room allows, if not what about cutting them off on the nut side witha cutting torch. or you could try and sock the nuts with penentrating oil, never that less good luck and nice lookn ride |
01-21-2007, 11:33 PM | #6 |
Re: finally started
nice truck you got there, i wish you goodluck with your build
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
01-21-2007, 11:37 PM | #7 |
THE VILLIAGE IDIOT
Re: finally started
nice starting point... soak the bolts in a good penertrating oil,,pay the extra money for the good stuff..good luck with your build
honestly honey,,i have no idea how that truck got here. |
01-22-2007, 04:27 PM | #8 |
Re: finally started
I just drilled out all 48 thousand of 'em... took a little over and hour but seemed the easiest way to me... used a bit about the same size as the bolt... went rather well. Nice rig by the way!
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
01-22-2007, 04:54 PM | #9 |
Designated A-hole!
Re: finally started
Looks good!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
01-22-2007, 05:12 PM | #10 |
Re: finally started
Tighten them till they break, Cutoff wheel if you can get to the bolts, or drill them out from the top.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
01-22-2007, 05:42 PM | #11 |
Re: finally started
01-22-2007, 05:54 PM | #12 |
someday it will be done!
Re: finally started
I got lucky and most of mine came out easily.For the ones that didn't,I used a zipcut on the nut side of the ones I could reach and used a torch (very very gingerly) on the ones tucked inside the cross supports.
The thing that bugged me the most was that the bed was held together with half a million bolts,but gm still felt it necessary to tack the sides to the rear cross sill.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
01-22-2007, 09:18 PM | #13 | |
Re: finally started
Thanks all for the kind words and advice. I soaked all the bolts over night. I only had about twenty minutes to play with it today(domestic duties were a callin') Two bolts came right out, and I drilled out three of 'em. Hoping to get an hour or two in tomorrow and have the bed off and apart, but we'll see what the bolts have to say about it.
Ken Quote:
Although I'm sure its there for a reason? |
01-22-2007, 09:28 PM | #14 |
Re: finally started
NICE
WELCOME TO THE BOARD |
01-22-2007, 09:40 PM | #15 |
More hobbies than money!
Re: finally started
If I ever finish my truck that will be my next one. Love the long bed 4x4s especially the heavy types.
'70 cst10/swb 350, 3 on the tree, factory buckets. '70 GMC lwb 350/350 ps,pb '72 c-10 lwb 350/350 a/c, ps, pb '72 Blazer project |
01-23-2007, 10:44 PM | #16 |
Re: finally started
Made a little progress today. Got left bedside off. I took a grinder and made a slot in the head of the bed bolts for a screwdriver worked like a champ! (used a dremel to make slots for the bolts in corners). If I can, I'll try for the other side tomorrow.
ken |
