04-24-2002, 06:01 PM | #1 |
Member since 2000
one more time, adjusting valves
at least she run , but she runs like crap, ok, can some one give me the best way to do this, i dont care if i have to rip the block apart. i want this done right, thanks
------------------ Mechanic @ California Concept Britney: 1970 2wd K/5 Blazer (Frame up) Jessica: 1967 2wd SWB (pops daily driver) Helga: 1972 4x4 3/4ton LWB (my daily driver) AIM:Alexmart1 Mountain View, Cali |
04-24-2002, 06:04 PM | #2 |
Maybe this will help; www.centuryperformance.com/valveadjustment.htm#Engine%20
72 SWB parts and pieces Oklahoma |
04-25-2002, 03:42 AM | #3 |
Member since 2000
TTT, help!
04-25-2002, 05:55 AM | #4 |
Captain CAAAVVVMMMAAANNN!
ok thhis is the way I do it on a 350. get the valve covers off and start it up. loosen each rocker slowly until it starts to "tick" and then tighten just enough to take the tick out. go through all rockers this way. Then go back to each rocker and loosen them again as above to ensure they were not way to tight and are fully "pumped up". After all are adjusted to where the tick has just been removed. shut it off and go through and tighten each rocker a half turn (180 degrees). put her back together and try her out. I have done this to many motors and haven't had any problems, hope it helps.
------------------ 72 LWB Fleetside C10 Custom 350/350 97 GMC Yukon 4X4 SLT Anna, Texas
72 LWB Fleetside C10 Custom 350/350 97 GMC Yukon 4X4 SLT Anna, Texas check out the project old yeller |
04-25-2002, 08:46 AM | #5 |
I do mine the same way Oldyeller has described,with 1/2 turn preload. Another thought, is that if the engine ran loose for some time,the plungers may be a little sticky when set at the depth that they should be. In that case, I would set the preload @1/8 to 1/4 turn,& see if that helps. I have run them as loose as 1/8 turn(to gain a few revs), but they will need adjusted more often. good luck......69 longhorn.
http://community.webshots.com/user/hotrodhorn |
