Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-22-2007, 12:12 AM   #1
7T2
Active Member
7T2's Avatar
Ford 9" Rear end - fits C10 73-87 - Central Ohio
I have a Complete Ford 9" rear end that should work in a 73-87 2WD C10 truck without too much modification, I have been told. It has a new set of no-slip gears (2.75 ratio), and 28 spline axles with 5 on 5 bolt pattern. It measures 58-59 inches from flange to flange. Currently has disc brake mounts on the axles that are probably for a big Lincoln. It also has tapered bearings on the axles that may be hard to find races for (races are pitted), but you'll most likely be taking it apart to lose the disc brake mounts anyway so new bearings could be added then. I believe everything else is complete. It is loosely assembled now and will need to be setup/shimmied/adjusted before it can be used. Housing has a large gusset welded onto the back of it for strength. Needs nuts to hold pumpkin on, and nuts and bolts for the axle flanges.
Asking $400 or best offer for the whole setup.
7T2 is offline   Reply With Quote
Old 05-03-2007, 09:00 AM   #2
7T2
Active Member
7T2's Avatar
Re: Ford 9" Rear end - fits C10 73-87 - Central Ohio
sold
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
