01-22-2007, 01:39 AM | #1 |
Why will me ignition turn on my motor, but not turn it off??
Im new at this whole classic truck thing!
thanks in advance |
01-22-2007, 01:48 AM | #2 |
Re: Why will me ignition turn on my motor, but not turn it off??
does your 12v power wire to your coil go to a switched fuse?
i had the same problem with my HEI until i ran the 12v to a switched fuse. |
01-22-2007, 01:51 AM | #3 |
ill check that out, any other suggestions? is the ignition shot?
01-22-2007, 01:52 AM | #4 |
Msgt USAF Ret
It's hard to say with so few details but here are a couple of ideas.
http://67-72chevytrucks.com/vboard/s...light=ignition
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-22-2007, 09:18 AM | #5 |
its all about the +6 inches
do you have an electric fan? If so, unplug it and see if it stil does it.
01-22-2007, 10:19 AM | #6 |
Semi-Senior Member
Has i t been converted to an HEI dizzy?
Scratch that. Has it been converted to an internal reg alternator?
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab Last edited by 68speedalert; 01-22-2007 at 10:21 AM. |
01-22-2007, 11:06 AM | #7 |
Self-proclaimed LED man
Trace the wire that comes out of the distributor cap (hei) and see where it leads. That wire is what kills the ignition so if it always has power, you cant turn it off. If its plugged into the fuse panel, its probably not on a swichable igniton key hot plug, and thats why you cant shut it off.
01-22-2007, 11:55 AM | #8 |
Sierra Grande Club
Have you changed anything lately? There’s a wire on the new style alternator that will keep it running in connected.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-22-2007, 06:35 PM | #9 |
The electric fan is wired directly to the battery so that wont do anything, also im pretty sure its to do with the alternator. so that should be a quick fix
01-22-2007, 06:59 PM | #10 |
Questionable
If the distributor is wired directly to the battery, your truck will run forever till you lift that wire. The coil on your distributor should be wired to a 12v ACC power, not constant power. This kills the power to the distributor when the truck is turned off. No power means no firing.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
01-22-2007, 07:30 PM | #11 |
~Rest In Peace~
i would get that electric fan wired to relay instead off the battery
just my .2 cents any1 else agrees ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
01-22-2007, 07:47 PM | #12 |
Msgt USAF Ret
The fans have to be wired through a coolant temperature sensing switch or they would run constantly. They might be wired through the ignition switch and powered on with the key. If so I agree with 70blowngmc about the relay.
They should be powered by a relay anyhow if run through the TSS. check out this link and read paragraph 2. It shows how the engine could run if the alternator is wired wrong. http://www.6066gmcguy.org/charging.htm
01-22-2007, 08:05 PM | #13 |
Semi-Senior Member
Makes sense to me....don't need heavy gauge wire running to the coolant switch. Much cleaner install. Actually, most switches aren't designed to operate the high amp draw of the fan itself.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
01-22-2007, 09:11 PM | #14 |
I just have a manual switch to turn on the fan, its much easier
01-22-2007, 09:14 PM | #15 |
how do you have it on relay?
