Old 08-25-2002, 05:50 PM   #1
treefrog
Hei
What is the advantage of going from stock distributor sytem to HEI? TF
treefrog is offline   Reply With Quote
Old 08-25-2002, 05:57 PM   #2
Tim Christian
Tim Christian's Avatar
Smile
You don't have to mess with no points for one.
Tim Christian is offline   Reply With Quote
Old 08-25-2002, 05:58 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
More dependable, better starting and better running through the RPM rage from a better, more dependable spark.
Also never dealing with the stupid points again in your life.
Old 08-25-2002, 05:58 PM   #4
hjalbert
cracker
hjalbert's Avatar
hmm, well on mine, my old points distributor just plain old sucked. i like my HEI , all i can say is when you put it in you will notice a huge difference, and then you dont have to worry about adjusting the dwell or replacing your points or anything, and you can get those big high power coils hehe
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 08-25-2002, 10:13 PM   #5
CoryM
#1 reason is that points/gap lose spark at 4500 drastically. I had points/gap on my truck and did a top speed run and the revs stopped at 4500rpm cause my spark got too weak to push it further. (got it to the P in MPH though ) You will not regret going to HEI.
Happy Trucking.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 08-25-2002, 11:32 PM   #6
weasel29gm
SLOW BUT SURE,BUT CLOSER
Hey Frog, if you can get a HEI do it, makes life easier!!!!!!!!! I've used it for years.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 08-26-2002, 06:45 AM   #7
treefrog
Hei
Thanks guys. Here goes a few more $$. TF
Old 08-26-2002, 06:57 AM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If it is a rebuilt unit, you'll be ready to go when it is installed. If you buy a used one, be aware that there are a couple of components that are replaceable, when bad. The module and the capacitor that is attached to it, can go bad and your engine will die and not start until replaced. If and when you replace the module, be sure you use the correct heat sink compound that will be in the box with the module.
Other than that, you'll love the lack of maintenance required, compared to points-type.
You'll have to install new plug wires....for a '76 and up V-8.
Member Nr. 2770
