01-22-2007, 02:55 PM | #1 |
Proud owner of a 55.1 AD
Computer Mount Location
Hello,
I have a couple of quick questions for those of you that are running computer controlled engines. Where are you mounting your computer? What type of mount are you using and where did you get it? I am in the process of putting 6.0L & 4L80E in my '69. I want to put the computer under the seat. If there are any reasons that I have not considered I am sure you will be able point me in the right direction. Thank you in advance, Bob |
01-22-2007, 03:04 PM | #2 |
www.73-87chevytrucks.com
Re: Computer Mount Location
You can mount the 6.0L computer anywhere you want inside or outside the cab. There is no reason you cannot mount it under the seat.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-22-2007, 03:16 PM | #3 |
Im putting the PCM for my LT1 swap in the same location it came from...front left of the engine compartment. I figure I might buy an auxiliary battery tray and mount it on that. I was thinking at one point about mounting it in the cab near the glovebox but if the factory location was good enough for GM engineers then its good enough for me.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
01-22-2007, 07:44 PM | #4 |
Long Fleet Club
I was thinking about on the firewall behind the glove box but I have no idea how much space the factory air a/c is going to take up. Anyone have any installed pics of this?
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
01-23-2007, 02:06 PM | #5 |
What type of mount is being used to hold the PCM?
Thank you. |
01-23-2007, 03:20 PM | #6 |
Questionable
Lack of wire is a good reason Mine won't reach that far.
A recent post showed someone mounting on the inner fender next to the pass. side of the block. I was going to run a grommet on my heater delete plate and mount it under the glovebox, then move it later when I can afford a better harness. I have seen most people mount it on the inner fender or inside of the fender somewhere. The most important thing is this: If it can come in contact with water, make sure the contacts (red and blue connectors) are pointing down so water won't drip and pool in them.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
01-23-2007, 06:02 PM | #7 |
What is used to hold the PCM?
On mine there are no mounting holes of any kind. I need to visit the dealership to find out how it is mount in stock form. Thank you for checking..... |
01-23-2007, 11:38 PM | #8 |
Questionable
You'd need to go to a junkyard or find a friend with a '98-02 F-body to find that one out. My PCM is held in a plastic housing. It is supposed to bolt to the firewall in the stock car.
01-23-2007, 11:40 PM | #9 |
Mine will go under the seat....
01-24-2007, 10:21 AM | #10 |
chevelito
Someone put it on a low hump and covered it with a high hump. Thought that setup was sweet. Easy access. When I do it, I'll put all my electricals like that (bags, fuse box, ecu). Cover it with a carpet and voila...
New deadline...when my son can drive. Aloha from Honolulu, HI |
01-24-2007, 03:38 PM | #11 |
Well, he was asking about a new harness and Painless has one for only $530, 40 mone and it is about 8 feet longer....
01-24-2007, 04:29 PM | #12 |
Junior Member
Mine is in the glove box, I made a braket to house it there. No chance of putting the glove box liner back in but with a center console I can live with it. Doing this let me run the wires for the engine compartment behind the heater box out of site. I am also using the electronic throttle control constrol so it works out nice.
I had to drill a hole through the firewall to run the wires but I put it low and behind so it's hard to see and makes a clean look with the wires. Bill
1972 K/5 4x4, Radixed LS1 6.0, 428HP/445TQ, Lingenfelter GT2-3 cam, WCCH 90mm J-Tube, LS2 90mm TB, Stainless Works Headers, NV4500, 4.56 gears, Detroit Lockers, 14 bolt FF, Dana 60, 4 wheel disk Hydro Brakes, dual electric fans, Autometer guages, 4" lift, Zero Rates, Weld Evo Velocity XT8 wheels, 35x12.5x17 Super Swamper SSR's..... http://s72.photobucket.com/albums/i1...tos/?start=all |
01-24-2007, 09:39 PM | #13 | |
Questionable
My stock harness (post-hacking by Wait4Me Performance) has just enough to let it fit on the passenger kick panel, but barely. Won't quite reach the seat. I've been seriously thinking about buying a Speartech harness, I have physically seen their product in person, it truly is plug-and-play, and honestly worth every penny IMHO. (but ... again - $700 would lower my truck and I already have what I believe is a "working" harness)
