Sound Dampening Material - raammat - FatMat - DynaMat
How much is required to cover in a single layer the entire cab. From under rear window to top of firewall and inside doors?
Will 50 sq/ft do it? Or will it require more? Going to order this week and was wondering if the guys that have already done it could help me out. Don't want to order too much ... but on the same hand don't want to order too little. Thanks guys. |
Re: Sound Dampening Material - raammat - FatMat - DynaMat
You can't order too much because you can use it for a lot of different things. My "guess" is 60 sqft, but I haven't measured all of it. I am getting 100' just because and will double up on the floor, then I might do my headliner if I have enough.
I got this from Here
Front Doors Single cab, Extended cab, and Crew cab 8 sq ft PER door Rear Doors Extended cab 5 sq ft PER door Crew cab 8 sq ft PER door Headliner Single cab 15 sq ft Extended cab 20 sq ft Crew cab 22 sq ft Floor Single cab 15 sq ft Extended cab 22 sq ft Crew cab 26 sq ft Back wall Single cab, Extended cab, and Crew cab 8 sq ft |
Thanks guys ... 100 sq/ft it is ... with a little left over for good measure!
Here is a good website.
http://www.sounddeadener.com/
71 Chevy Stepside 377/350 |
#6 | |
Aren't you done yet with that thing? ![]()
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
This is a dumb question but has any one used *****ithane (SP?) for sound control? I have a large roll (250sq') left from doing my roof last summer and boy is it sticky on one side. The only thing is that it does not have foil backing on the one side but I do not see that as being a real big deal when I have it for free. What do you all think? I might try a small area and see how it acts before doing the whole thing.
Kevin LFD Inc. |
#8 | |
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
No. Since starting on this heap, I have:
Changed jobs ... 3 times. Moved ..... 2 times. Gotten married .... 1 time. Moved truck from 1 shop to another .... 2 times. I hope to drive the the thing this coming spring/early summer. No paint, just drive it. I am to the point where I don't give a rip what it looks like, I just want to DRIVE IT! ![]() P.S. Thanks for your concern and motivation! ![]() |
#10 | |
![]() ![]() Join Date: Jul 2002
![]() Rat rod is looking better all the time ![]() ![]()
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 01-22-2007 at 08:11 PM. |
#11 | |
Who better to give you grief than the guy that has had an entire front suspension rebuild, new dropped spindles and disks, new power steering, a Gennie shifter, and new Flaming River column, all sitting in the garage for over a year collecting dust ![]()
#12 | |
#13 |
Assuming the sound reduction performance is about equal with Dynamat, Looks like $99.00 for 100 sq feet of FATMAT at Sounddeadener.com is the best option to me.
#14 |
I remember seeing a website, where some guy did some in depth testing of multiple brands (dynamat, fatmat, and a couple others), comparing Cost and effectiveness. cant remeber if the link was posted here, or on my camaro forum.
I'll see if i can find it. EDIT---> Found it. it was right here on this site. Sound Deadener Showdown The Thread
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 01-22-2007 at 08:21 PM. |
#15 | |
Prior to reading, I was FATMAT bound because of its low cost per sq foot, and low cost per pound. Now after reading about its adhesion problems, I'm thinking of using the FATMAT (or Peel and Seal if it's lots cheaper) only for the horizontal surfaces, and use the recommended RAAMmat BXT with its better adhesion properties for the vertical and overhead areas. Great read. Thx again for the link .
#16 |
'69 Step
I bought a bulk pack of Dynamat extreme. One pack did both doors, firewall and the floor ONLY to the seat line.
#17 |
Thought I might as well test a few areas of my project cab and see how it does. Heat will only make it stick more and to install it I used a small tortch and just warmed it and stuck it down. I hope it does not need to come out!
Kevin LFD Inc. |
#18 |
#19 |
Rokcrln my only concern with what you are using would be smell when it gets the heat of the summer. Would it release any noxious fumes in an enclosed area (unlike when used on your roof) You might call the tech help at the makers of the material to ask.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
#20 |
Happy to be here
![]() Join Date: Mar 2000
Everyone needs to take the time to read the article that has been posted 2-3 times in this thread. DO NOT use roofing material unless you want it to fail. Failure can mean that it actually melts inside your interior and ruins your carpet. READ THIS
#21 |
Hand Crafted C-10
![]() Join Date: Aug 2006
I've used this: http://doitbest.com/DoItBest/Main.as...=64&SKU=260210 ...worked for me and only $20.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
#22 |
Great input guys....
#23 |
http://www.hotrodders.com/forum/alte...in-103610.html
found this on another board , very interesting
hey.....smell my finger 64 nova wagon , 63 nova convertible |
