67 chevy compared to 67 gmc rear end
Have an eaton ho52...8 lug...coils trailing arms rear ect...found a 10 bolt 8 lug leaf springs rear...out of a between 67 to 72 gmc not quite sure the year...are width the same?...I know they make kits to change over...I beleave its a Dana 60?...is this possible in them year gmc's...want to put it under My 67 Chevy 3/4...Need taller gears...specs would be nice on gmc
![]() Join Date: Aug 2005
Re: 67 chevy compared to 67 gmc rear end
It probably is a Dana 60. A Dana 60 with leaf springs is very common on '67-'69 GMC's. Width is the same, but as you probably know the mounting pads on the axle are completely different.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
Thanks Bob...I beleive brothers sells a kit for mounting pads to put them on coil/trailing arm truck...
