Old 01-22-2007, 07:53 PM   #1
bobthecop
bobthecop's Avatar
vortec heads
I have a rebuilt set of vortec 906 heads, I was told that the machine shop did a 3 angle valve grind, will they be as good as the 062 heads???
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 01-22-2007, 08:08 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: vortec heads
well heres every thing i have on the subject
i have 062's and did not buy 906's because i could not get that answer..i think any vortec head is going to be better than 90% of the OEM heads out there...with very little work,they are the hot ticket right now.
the 906 has a different exhaust seat..which is supposed to cut flow a tiny bit?
http://67-72chevytrucks.com/vboard/s...ghlight=vortec
rage'nrat638 is offline   Reply With Quote
Old 01-22-2007, 08:15 PM   #3
rage'nrat638
Re: vortec heads
heres installing LS1 SPRINGS on the vortec heads
http://67-72chevytrucks.com/vboard/s...+valve+springs
Old 01-22-2007, 10:11 PM   #4
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: vortec heads
I new to posting on here so i'm trying to figure out how ad a link so you will have to go there on you own but sallee chevrolet discussion board has some info. Besides that I'v done alot of engine builds circle track and street. From what little experience I have had the 906 heads I have used worked great on claimer motors only changing valve spings. They do run 10 to 15 degrees hotter than most. Timing and jetting seem real important to these heads.
RACINJASON22 is offline   Reply With Quote
Old 01-23-2007, 09:28 AM   #5
bobthecop
bobthecop's Avatar
Re: vortec heads
I guess I'm just hoping I haven't messed up by going with the 906 heads. I was wondering if a 3 angle valve job is possible to be done on the 906, and can I still get 350+ hp form them, I have a 350 bored 40 over, cam and carb still to be purchased.
1972 C-10
Old 01-23-2007, 10:55 AM   #6
RACINJASON22
GEARHEAD
Re: vortec heads
I did a little research seems that the heads a basicly the same castings. They have different valve seats and such. Also when I changed my valve springs I had the machine shop cut the spring pockets to run larger diameter
springs. three angle valve job should be no problem. Do your research on cam and carb selection remember bigger is NOT always better unless you want to run wide open all day long. 350HP should be fairly easy to achive.
GOOD LUCK! KEEP US POSTED.
Old 01-23-2007, 11:09 AM   #7
bobthecop
bobthecop's Avatar
Re: vortec heads
Thanks for the input, I knew I would find the right answers here
1972 C-10
Old 01-23-2007, 07:30 PM   #8
pkj
Re: vortec heads
i thought 906 came with 3 angle valve job?
pkj is offline   Reply With Quote
Old 01-23-2007, 08:00 PM   #9
Ram-Man
Ram-Man's Avatar
Re: vortec heads
My recent trip to the machine shop that I have grown to trust told me that the 906 vortec heads are the least likely to crack. He said if I am looking for cores to get the 906's. Maybe just his 2 cents worth.
Ram-Man is offline   Reply With Quote
Old 01-24-2007, 10:09 AM   #10
bobthecop
bobthecop's Avatar
Re: vortec heads
Well I'm gonna use them, and see how they perform, I guess they need to back to the machine shop and have work done for Lt1 springs, gonna run a hefty cam.
1972 C-10
Old 01-24-2007, 11:12 AM   #11
Billla
Billla's Avatar
Re: vortec heads
The 906's were used in heavy-duty trucks. They are the same casting, but they have Iconel, single-angle valve seats. If someone has gone in and done a 3-angle seat (likely replaced the seats) and reground or replaced the valves...then they're the same as all the others.
This machine work is kinda spendy, and it sounds like you got them from someone with no documentation - no machine shop bill. I would definitely pull a valve and make sure you have what you think you have if this is a performance application. If this is for your daily driver and you're not going over .450 lift on your cam...stop worrying
Billla is offline   Reply With Quote
Old 01-24-2007, 11:19 AM   #12
Billla
Billla's Avatar
Re: vortec heads
I should have read all the way through the thread
Have the machine shop double-check the valve seats while they have them apart.
I don't recommend the LT1/LT4 valve springs (P/N 12551483); they're cheap (~$40 for a set) but they are lift limited to .525 and the seat pressures aren't great for a big cam - LT1 builders are seeing valve float as low as 5200 RPM in some applications. IMHO there are far better springs available from CompCams and others...but admittedly at about 4x the price. They're GREAT for a stock-ish rebuild for less than .450 lift.
I agree that you don't need a big cam to make 350 HP, and at that build level you don't need to upgrade springs.
Old 01-24-2007, 11:23 AM   #13
bobthecop
bobthecop's Avatar
Re: vortec heads
Thanks, seems ya'll are saving me money all the time
1972 C-10
Old 01-24-2007, 09:43 PM   #14
jake60
Re: vortec heads
Does anyone know anything about 041 heads? I have a set I was thinking about using.
"Common sense is very uncommon" Rudyard Kipling
jake60 is offline   Reply With Quote
Old 01-24-2007, 10:11 PM   #15
rage'nrat638
Thumbs up Re: vortec heads
heres what mortec say's
3947041....69-70...302/350......"Right angle" casting identifier, 64cc chamber, accessory holes, good HP head
if these are true 302 heads there worth there weight in gold
Old 01-24-2007, 10:25 PM   #16
RACINJASON22
GEARHEAD
Re: vortec heads
041and 041x heads Don't want to get of track on the original question but those heads were always really good on the track. And as for what ragn'rat said you could even get you gold frome someone doing a #'s matching build those heads are getting very hard to come by.
Old 01-24-2007, 10:27 PM   #17
jake60
Re: vortec heads
I wish! Unfortunately they were on a full size 1969 350. Evidently Chevrolet used the same casting number for several applications.
Old 01-24-2007, 11:08 PM   #18
RACINJASON22
GEARHEAD
Re: vortec heads
Regardless of what they were off of they are still a good set. same flow numbers as 186,461,461x (ie) fuelie heads, camel hump, but with the bolt holes in the front like the 186's they came in 1.94 and 2.02 intake valves under that same casting #
