01-22-2007, 07:55 PM | #1 |
6" spring and bolt in notch
How much travel do you have when you do a 6" spring drop and a bolt in c-notch between the axle and notch? I am thinking of going to a 6" drop in the rear and going 2" more in the front to get it on the ground.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
01-23-2007, 02:53 PM | #2 |
Re: 6" spring and bolt in notch
I have a 7" drop in the back and a 3" notch and there is plenty of clearance. don't have access to measure right now but its prob 4-5".
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
01-23-2007, 09:26 PM | #3 |
Is that with a stock floor? I have a wood bed and don't want to change anything like that
01-23-2007, 09:57 PM | #4 |
My trucks has bags, 1.5" blocks & a bolt-in style c-notch. The top of the rearend hits the bed floor before the axle tubes bottom out in the notch. A 6" drop w/this style notch would work fine.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-23-2007 at 09:58 PM. |
01-23-2007, 10:57 PM | #5 |
Thats what I needed Thank you.
01-24-2007, 01:05 AM | #6 |
Your wood will go unchanged. I see no problem whatsoever in doing what your thinking about.
Scoti how big is your notch that you are hitting the bed first? just curious.
01-24-2007, 09:35 AM | #7 | |
I have removed the factory bumpstops on the outer frame rails so the center of the rear-end housing hits my wooden bed floor (or what's left of it) before the axle tubes hit the top of the notch.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-24-2007 at 09:36 AM. |
