Old 01-22-2007, 11:03 PM   #1
agronomya
Junior Member
agronomya's Avatar
Column??/Tranny?? problem...I guess
Ok, I have a little problem that I don't understand yet. I can drive the truck around all day and have no problem and it doesn't do this every time I put it into park. But the last few times it has been REALLY hard to put into park and you can kinda tell that the stopping/lock up point is in the column. It goes through all the other gears fine but whenever I back it up in the driveway and try to put it in park and it is just a bi*&^.
Any help would be great guys. Thanks.
AA
They call me, "AA."
1969 Chevy LWB-SDPC 350, TH400, old farm truck
http://s123.photobucket.com/albums/o299/agronomya/
2006 Nissan Altima-For my 2000 miles a month
agronomya is offline   Reply With Quote
Old 01-22-2007, 11:21 PM   #2
jhow66
jhow66's Avatar
Re: Column??/Tranny?? problem...I guess
Remove shift lever and spray WD-40 in hole and then under hood spray where the lever comes out of column. Should free it up.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-22-2007, 11:25 PM   #3
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Some of the other guys on her that have a better knowledge of these trucks might have a different idea but. I had a problem like this in a monte carlo it was in the tranny. I know you dont want to here that sorry. A quick way to check is to BLOCK YOUR TRUCK WELLThen unhock your linkage right at the tranny and shift it through the gears you will know right then tranny or truck atleast. Good luck hope this helps.
RACINJASON22 is offline   Reply With Quote
Old 01-23-2007, 04:07 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
odds are it is the column. They like to bind and are generally a poor design.
Old 01-23-2007, 06:14 PM   #5
agronomya
Junior Member
agronomya's Avatar
Thanks guys, I'll check tonight after work.
AA
They call me, "AA."
Old 01-26-2007, 08:34 AM   #6
MR MAGOO
MR MAGOO's Avatar
i have a turbo 350 and when i get in it to go to work in the am i have to wait till it warms up before the tranny will go in gear ? then sometimes it will go bout 100' and stalls again,just like it was in neutral. any one else have this problem w/turbo 350's?
MR MAGOO is offline   Reply With Quote
Old 01-26-2007, 11:40 AM   #7
jhow66
jhow66's Avatar
Front pump is worn. Time for a rebuild.
Old 01-26-2007, 12:10 PM   #8
MR MAGOO
MR MAGOO's Avatar
it has done that since it was rebuilt. does that mean they put a bad pump in @ the tranny shop?
Old 01-26-2007, 03:30 PM   #9
jhow66
jhow66's Avatar
Have you taken it back to them? How long since rebuild?
Old 01-26-2007, 05:41 PM   #10
Longhorn Man
I woulda gone straight back to the rebuilder.
Double check the fluid and call your shop. (you DO know to check the tranny fluid with the engein running, up to oporating temp, on level ground, and just after going through all the gears, right?)
