Project 7dos
Power Windows?????
Does anyone know where i can get a power window kit for a 72?? I have seen them before but just forgot where. If so can you tell me how much $$$$. and how easy are they to install???/
thanks Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
I need another Barley Pop
I bought mine here: http://www.a1electric.com/
I think the price was either $239 or $269 and they just bolt in place of your stock regulators (with the exception of running the wires through your door jambs). Takes a little time to run the wiring for the switches. I mounted my switches over the stock hole in the door panel for the window crank. Covered it perfect, can't even tell there was a hole there.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
![]() Join Date: Dec 1999
i did the same thing as pont. they couldnt have made it easier boltin right up to your stock regulator holes. but i think he bought a different switch than me cuz mine wouldnt fit in the stock crank hole. i went ahead and cut another one a little closer to the armrest, and im plannin on reupolstering my interior so the old hole will be covered someday
Pont- how long have you had them in? ive had mine for a little over a year and my passenger side motor seems to be slowing down
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
gabet40, I have had mine in for about 1 1/2 years and I have the same thing happening with my passenger window. It seems to be slowing down or at least not working as fast as the drivers side. I was thinking that I need to pull it apart to re-grease the channel or see if it was binding somewhere. After hearing that yours is doing it also, now I'm thinking that there must be some manufacturing flaw with the RH motor on these regulators because my passenger side gets used alot less than my drivers side. Hmmmm, now you've got me thinking.................
no kidding!? man, im glad i said something. i was thinking of regreasing as well but now i think im gonna give them a call and see if theyve had other people with the problem. i think ill check out the warranty info and my purchase date as well. if it is the motor maybe we can just exchange it right over.
I'm glad you said something as well. I will be contacting them to see what gives and what they are willing to do. Thanks for mentioning that, I figured it was just me!
Make that three guys. My pax window is slow too.
The more I learn about women, the more I love my truck. |
I bought the Speciality Power Windows. You do have to drill a couple of holes and remove the window stop but the are very high quality and have a life time warrenty.
i called yesterday and the tech guy said that the regulators/motors have a lifetime warranty. so he said if i take it off and send it back to them theyll send a new one at no charge. he said to take a voltage meter to it first though to eliminate the possibility that it might be a wiring problem, but with all these different cases, im pretty sure its the motor.
so once it cools off a little here in cali and i dont need to be rollin the window down, ill take it off and send it back in for a new one
I had the same thing happen to mine, the passenger window would hardly work, while the driver side was really fast. I took the switch out, and it was starting to rust inside. I wd-40 the switch and both windows operated the same. I beleive the current runs through the switch, so basically there was just a bunch of resistance in the switch - I would try this first.
Over worked under paid
Wing windows
Has anyone converted their wing windows to power?
Roger '69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears |
Ive been thinking of a way to try this too. I remember my uncles car when I was a little had power vents but cant remember what kind of car it was.
#13 |
![]() Join Date: Jan 2002
I have an 85 Olds Cutlass Supreme that has power wing windows in the back doors. They look strange opening and closing by themselves.
#14 |
GYRO GEARLOOSE
Why you guys spend all that money for a power window kit is beyond me. THe belt drive mechanisms from newer GM cars work teriffic and use GM switches. HTey practically give the motors away at the junk yards. Below is a picture of a motor shown in the position it occupies in teh door, it pushes on the lower window channel, after you remove the gear from the old regulator.
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
#15 |
TERRYP did you remove the drive band and straiten the chanel that the band goes in ,becouse it was designed for a curved glass and ours is flat?
I have done this ,just never gotten to install it yet. A word of advice to everyone wanting to do anything to thier glasses, if your chanels and felts are not in great shape you will have less than satifactory results no matter what else you do to your windows.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air. 68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles 68 anniversary no engine long wheel base 400 auto FOR SALE 68 Chevy fleet side long wheel base complete parts truck. |
#16 |
Half a bubble off!
Hey TERRYP and chevyman, how about doing a step-by-step how-to on this window retrofit? And what year GM regulators apply here? I'm sure there are many others here on the board that would be interested like me. And I will readily admit that I am mechanically challenged, especially concerning these windows.
This seems to come up a lot here on the board, it would be nice to have some really good reference material on the subject. I would be willing to help write it up if I had some info to go on. ![]()
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
#17 |
Back in the sticks
I have the same kit as you guys and the passenger does go slower. I'll have to check it too. Thanks for starting the thread. Someday I'll actually finish the new armrests and get the switches mounted. ha! I do love this kit though. So easy to install(with the exception of running the wires). Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#18 |
Half a bubble off!
Just out of curiosity, since everyone keeps pointing to the passenger side and saying the motor is slow, I have a question. Do these window kits use different motors for driver's and passenger sides? If it is the same motor on both sides, then I would lean towards thinking it could be a wiring problem. It would be an awfully strange coincedence that only the pass. side motor would be a problem if both sides use the same motor.
#19 |
I have a 68 chevy with, i think, ruined regulators, they come out of the panel bent. They are also stripped. My brother has a totaled 88 Chevy pickup with power windows that I can have parts off of. TerryP, or anyone else, is this a simple, cheap mod? If you know good directions and steps for installation please share them. Thanks
#20 |
well i took off my panel and all and when i started playing with the wires in the dor jam they popped a fuse. so one of em must be worn and was grounding out so i readjusted those so they arent grounding out, made sure i was gettin 12 volts, which i was, double checked the connection to the motor and put it back together.
after all that playing with it, it DID go up a little faster, but still not up to speed with my drivers. but i reccommend taking it apart and checkin everything, cuz it made a little difference with mine. then lets see where were at
#21 |
The window controls I used came from a olds 88 around 86 model, as far as showing the prodject I haven't completed it so I can't give the complete final info, but I see no problems at all around the corner everything has checked out so far.
The regulator you are looking for is the ones with the nylon band that slides in the track to raise and lower the window. It needs to be mounted to thebotom track that attaches to the window pretty close to the center of the window and the motor and bottom of the unit mounted to the door firmly. The glass rides up and down in the original track WHEN i GET MINE MOUNTED AND WORKING i WILL POST SOME PICS
#22 |
GYRO GEARLOOSE
Chevyman 68, you'll fimnd that the GM belt drive motors work best when the lifting point is surprisingly far back from the center of the window. I discovered this by trial and error on a few trucks. These devices can be used without the regulator pantographs if the lift point is good, but getting your windows to slide nicely with the stock pantographs works the smoothest. I'm gone for the next week. I'll post other pictures, especially my 68 when I get back.
Here is a picture of my 66 with the motor installed. Note the lift point! ![]()
