dual feed carb plumbing
i would like to see some pics of some of the ways people have set up there fuel lines for dual feed carb. thanks, pkj
![]() Join Date: Jul 2005
I run a braided line to each bowl from the pressure regulator . Sorry do not have a picture. There are one inlet from tank and two outlets on the regulator I have . Also I have a fuel pressure gage at a nopther pposotion on the regulator. Hope this helps.
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
Re: dual feed carb plumbing
I bought one of those cool duel braided line setups from Russell, I don't have a picture but it was nice & clean & easy.
Larry, what kind of regulator is it? If it's a holley, it may not be supplying adequate fuel to your carbs. I know, everyone does it. The holley regulators have a tiny orifice for the fuel to flow thru, even smaller than one (1) needle/seat in a holley carb. It's .090 for the regulator and .110 for the aftermarket needle/seat. I worked a setup last year with a 6-71 on a bb chevy and that was the issue. He had 1/2" fuel line with a Y block, going to 2 holley regulators and was way lean in the upper rpms. Not saying this will apply for everyone, but if you're having a lean issue, could be the problem.
It's a catastrophic success.
![]() Join Date: Jan 2003
I used the solid chrome one but if everything doesnt line up they can leak but the flex ones are more expensive.
#6 | |
![]() Quote:
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 Last edited by larry may; 02-01-2007 at 01:42 PM. |
New Member
I used the solid chrome one and turned it backwards. Then turned my distributor so that the vac. adv. canister was the other way. Ran the fuel line up the back of the motor it may be hard to see in this pick but I can take another if needed. Please do not laugh too much at the condition of my truck it was wrecked and has been sitting almost a decade... I plan on getting it back on the road soon!!!!
1969-72'ish C-10 SWB Step 1997 Chevy Z71(sold) ![]() 2005 Chevy Crew Cab |
thanks everyone. i want to do something differant. i know i cant run long pieces of rubber fuel line safley. i saw some blue 3/8 inch rubber hse at a circle track supply house. not sure what it was for but looked like some tough stuff. any ideas on this? pkj
![]() If you look closely, you can see I ran the blue silicone hose from the fuel pump to a billet Y block in -10. From the Y, I ran -8an braided stainless to -8an fittings on the carb. This is in my daily driver malibu. |
18 Till I Die
Nice and Neat. Base bracket is either Morosso or Holley. fits between carb and intake. Made my own fuel lines with Russell Stuff. Regulator is Holley.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
