01-23-2007, 11:37 AM | #1 |
The Engine Whisperer
17-Spline
Does anyone have an idea of when 17-spline center sections and axles were made? Will normal 12-bolt components will work with 17-splines?
thanks in advance ProStreet68 |
01-23-2007, 06:37 PM | #2 |
Re: 17-Spline
ttt
01-23-2007, 07:22 PM | #3 |
Fabricate till you "puke"
Re: 17-Spline
The 12 bolt has 30 splines......what has 17?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-23-2007, 09:18 PM | #4 |
Active Member
Re: 17-Spline
The 12 bolt rearend in my truck. I am still digging up information on what year. I do know the guys that build rear ends know about the 17 spline units. I posted the same question over on the 60-66 board. I hope the reply.
I am going to go down and pull of the axel code and date tomorrow. Some Vette's had 17 spline also according to Eaton.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
01-24-2007, 03:40 AM | #5 |
Re: 17-Spline
my eaton h072 has 17 spline shafts, never heard about the 12 bolt with them.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
