Old 01-23-2007, 05:02 PM   #1
MudBug
MudBug's Avatar
Small Block to Big Block Swap
What is needed to replace a small block with a big block? I have a 1970 GMC long wheel base and a freebee 402 big block that needs a good home.
MudBug is offline   Reply With Quote
Old 01-23-2007, 05:34 PM   #2
cruiserman
Re: Small Block to Big Block Swap
2WD or 4WD?
You need motor mounts for one thing .
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 01-23-2007, 05:37 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you just wanting to stuff this sucker in there, or are you trying to make it look like it came this way?
There's a few ways to do it, some better than others.
Old 01-23-2007, 05:44 PM   #4
matthufham
fan shroud if desired, motor mounts, exhaust manifold/headers, if you have a th350 it'll work but i'd swap that for a th400, you might want a larger cfm carb too. anything else?
matthufham is offline   Reply With Quote
Old 01-23-2007, 06:03 PM   #5
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-24-2007, 12:24 PM   #6
MudBug
MudBug's Avatar
I would like to keep it stock looking but aint afraid to use new parts.The truck is a 70 model GMC 2 wheel drive with a 350 motor and trans and leaf spring rear suspension.Do you change the motor stands on frame or will a blig block drop on the same stands?
Old 01-24-2007, 12:36 PM   #7
novajess1972
novajess1972's Avatar
You can use the SB motor mount brackets if you are using stock exhaust manifolds. I had to go with BB motor mount brackets to make my Hooker Headers work. The BB brackets have a recessed area to allow for the aftermarket headers. I had to locate BB P/S pump brackets and BB alternator brackets. Be sure to find a 4-row radiator if you dont already have one.
That's all I can think of at the moment.
Good Luck!!!
1985 SWB Silverado 1/2 Ton
1972 Chevy SWB 1/2 Ton (sold)
1972 Chevy Chevelle SS (sold)
1971 Chevy Nova (sold)
1967 Chevy El Camino (sold)
2001 Mustang Bullitt (sold)
2019 Toyota Tundra Crewmax (daily)
novajess1972 is offline   Reply With Quote
Old 01-24-2007, 12:45 PM   #8
MudBug
MudBug's Avatar
Thanks , I'm already got a alinumin dual pass radiator thats the same kind we use on a stock car with a 431 small-block, If that don,t work i'll try something different.I got the 402 from saleing a street stock and the guy didn't have enough cash. I put the motor on a run stand and it sounds great, no knocks or weird noises, and pretty good oil pressure. Can you notch the motor stand for headers to fit? Thanks
Old 01-24-2007, 02:30 PM   #9
cduster
I couldn't get my stock manifolds to fit using the smallblock stands. Ended up getting the BB stands. That was my expirience.
Dan
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
Old 01-24-2007, 02:43 PM   #10
novajess1972
Can you notch the motor stand for headers to fit? Thanks[/QUOTE]
You CAN notch the stands, but I wouldn't recommend it. I'm no expert, but I would think notching would sacrifice the integrity/strength of the stand. And none of us want an engine to let go under acceleration. It may not happen right away, but it may happen down the road. Just spend the money to get the correct ones. If not new, there are some members on here that have used ones availalbe in the classified section.
Good luck
Old 01-24-2007, 04:03 PM   #11
Longhorn Man
i have actually been told that with headers, you can use small block stands... naturally, that will depend on the brand/model of headers. Bit to run the correct manifolds, you will need the correct stands.
Old 01-24-2007, 05:14 PM   #12
meathead95
computer illiterate
meathead95's Avatar
i have a set of nos bbc 68-71 stands if your interested pm me. also welcome to the board. where are you in tennessee?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 01-24-2007, 05:46 PM   #13
krue
Designated A-hole!
krue's Avatar
Please restrict buying and selling to parts boards and pm's.
www.daveramsey.com
