01-23-2007, 06:22 PM | #1 |
Weatherstrip
Hey guys, I know you have talked about how S10 weatherstrip works well for our trucks. Is the snap in part worth it? Are they all snap in? I have a link to an eba auction, will this work?: http://cgi.ebay.com/ebaymotors/WEATH...spagenameZWD1V
Manes has a pair for $25, would it be just as good to buy those and not have to pay the stupid ebay shipping and just glue it in? Thanks, Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s |
01-23-2007, 06:30 PM | #2 |
Re: Weatherstrip
I believe that's for the inside of the door that the windows rides on. That's not the door weather stripping you want.....
1997 GMC Sierra Ext 1965 Mustang |
01-23-2007, 06:32 PM | #3 |
Re: Weatherstrip
I believe you're right and I posted the wrong link. This is the right one: http://cgi.ebay.com/ebaymotors/82-93...QQcmdZViewItem
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s Last edited by bad72c10; 01-23-2007 at 06:35 PM. |
01-23-2007, 07:33 PM | #4 |
Re: Weatherstrip
Okay another question, has anyone ordered S10 weatherstrips from LMC, they are cheaper than Ebay. and about the snap in part of the S10 stuff, is it like a plastic clip or what? Thanks guys. Justin
01-23-2007, 08:00 PM | #5 | |
Re: Weatherstrip
You can also use the Caddy weather stripping with the felt on the inside if you buy tree pieces. Last edited by kyull67; 01-23-2007 at 08:02 PM. |
01-23-2007, 09:25 PM | #6 |
Fabricate till you "puke"
Re: Weatherstrip
I have a set of boneyard S dime seals on my 69. they are flipped side for side , & clip right on the old truck. the doors did shut very tight, but a little hammer work on the pinchweld helped that out. My old truck is wearin a 4" chop top, & the stock s 10 seals needed 4 or 5 inches chopped out of the bottom center......my bet is that they are a tad too short for a stock height cab tho..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-23-2007, 10:29 PM | #7 |
NCStroker
Re: Weatherstrip
i just bought some s10 seals for a $1.45 at the local pul-a-part. ill be putting them on this weekend.
1971 Chevy C/10-Built 383 Stroker |
01-23-2007, 11:14 PM | #8 |
Re: Weatherstrip
What also works well are the door seals off the 89-90 style full size truck. EXT56 did this on his smurf truck and I could not belive how well it worked. I will be hitting the pick-n-pull for a set for project "LFD's Low buck truck build" they will fit right in for this build.
Kevin LFD inc. |
