Old 01-23-2007, 08:27 PM   #1
cory321
Problem Child
cory321's Avatar
Doors won't lock
Okay when i lock the doors then shut the door the lock pops back up
It wont lock with the key.Anyone know how to fix thisThanks in advance
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
Old 01-23-2007, 08:31 PM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Re: Doors won't lock
Odd's are you'll need a new tumbler, because you cant lock the door then shut it.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 01-23-2007, 08:40 PM   #3
cdowns
cdowns's Avatar
no you cant lock these doors then shut them // if it wont lock with the key try some wd-40 or lock ease sometimes moving parts work a bit better if lubricated every 30years or so
Old 01-23-2007, 08:43 PM   #4
cory321
Problem Child
cory321's Avatar
the lock will move freely with the key it just doesn't lock
I Survived Norwood
Old 01-23-2007, 08:47 PM   #5
ratrod67
ratrod67's Avatar
Sounds like the lock rod came off. You'll need to pull the door panel off to check.
ratrod67 is offline   Reply With Quote
Old 01-23-2007, 08:47 PM   #6
rage'nrat638
rage'nrat638's Avatar
dito..these trucks only lock with the key after the door is closed..
you might try pushing in on the door while you turn the key..to compress the weatherstrip..
my passenger side locks fine with the door closed. the drivers side i have to push in on the door a little to turn the key..it's fine for me..but the wife has trouble with it
rage'nrat638 is offline   Reply With Quote
Old 01-23-2007, 08:51 PM   #7
cory321
Problem Child
cory321's Avatar
i'll try that thanks
I Survived Norwood
Old 01-23-2007, 09:15 PM   #8
e rock
It's only a couple clips, half a dozen screws, and maybe a flashlight to see what's really going on in there.
Spary some penetrating oil on things and I bet you'll be good to go for another 35 years. There is a little pivot arm (non-technical name) that has a large surface contact area in it's pivot point and that one is especially susceptible to freezing up with a little dry corrosion. Kind of hard to explain, but you'll see the one I'm talking about. All it takes is a little lube - not WD40 - you want something that will leave some lube behind but still wick into unexposed areas like pentrating oil does. "PB Blaster" is great stuff for this kind of work.
e rock is offline   Reply With Quote
Old 01-23-2007, 09:17 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
with the door open, can you lock and unlock the door with the key?
Old 01-23-2007, 09:39 PM   #10
cory321
Problem Child
cory321's Avatar
Yes I can Longhorn_Man
I Survived Norwood
Old 01-23-2007, 09:59 PM   #11
71swb4x4
71swb4x4's Avatar
Then you should be able to close it with Mark's tip. Just push on the door while you lock it, it should work. They must have replaced the weatherstripping when they repainted the truck.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-23-2007, 11:55 PM   #12
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
I had to do the "push in & up" thing with both doors on my 71. I replaced both the latch assemblys on the doors and they lock great now!
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 01-24-2007, 07:49 PM   #13
cory321
Problem Child
cory321's Avatar
I tried pushing in then locking but it still does'nt work.I am taking the door panel off tomorrow to look at it and compare it with the parts truck
I Survived Norwood
Old 01-25-2007, 02:49 AM   #14
sjarrett71
sjarrett71's Avatar
Just an idea, but can open the door then lock the door, then push in on the door handle button and then shut the door and it stay locked? I know some older cars you can do that with but not sure if it applies to these trucks. I don't dare try it with mine because I have no keys for my door locks. I'm waiting for my new door panels to come in before I change them.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-25-2007, 03:05 AM   #15
GREASEMONKEY72
GREASEMONKEY72's Avatar
nope i tried that when i first got mine before i learned that its a safety thing the only way to lock the doors is with them closed by using the key or pushing the lock down from the inside
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-25-2007, 03:58 AM   #16
sjarrett71
sjarrett71's Avatar
OK, so now I know too. Thanks.
-Scott-
Old 01-25-2007, 05:28 AM   #17
GREASEMONKEY72
youre welcome
-steven
Alte Seele S.S.
