01-23-2007, 11:15 PM | #1 |
How do you make 350+hp in a 350??
I'm looking at pulling a 350 out of a 69 c10 that supposedly has about 60-70k miles on it since a rebuild and I'm not for sure how many before that. I don't know because the previous owner put in this engine after the old one wore out, and this one was just a rebuilt one. Though it is still supposed to be a 69 350. Ok, enough with the life history. I want to make this engine produce 350+hp and if possible 400+ torque. So what parts do I need to put on this to do that. I'm looking at rebuilding the stock heads, new cam, intake, carb, headers with dual exhaust, all that good stuff. I will also be rebuilding it, pistons, rings, gaskets, timing etc. But no nitrous or blower systems. I would like to keep the fuel economy fairly high since this will be a daily driver, though I want some power to set me back in my seat when a really romp on it. I need good low end torque but would also like to be cruisin at 60mph and romp on it to pass someone and be able to tear right past them. So first of all do you think I can achieve that much power with an old motor or will I find all the weak spots. So if you made it this far without giving up, any suggestions???
I could really use your input on this.
1968 C-10 longbed, 307 V8, 4spd- currently under construction |
01-23-2007, 11:34 PM | #2 |
fugedaboutit
Re: How do you make 350+hp in a 350??
hmm sounds like somebody wants a zz4 crate motor..Or build your own for half the price. http://store.summitracing.com/partde...9&autoview=sku
Currently truckless |
01-23-2007, 11:54 PM | #3 |
I built a 1970 R/S Camaro a few years ago I used a 70 350 with 2.02 proflows in a set of double hump heads and the Elderbock performer package cam, intake and carb. It was .030 w/ flat tops. I had a 3:55 rear and a 5 speed. It ran on pump gas true HP unknown but a kick in the pants for a close to stock SBC. No regrets other than I sold the car 10 years was long enough. The key is match the cam,intake,carb,compression and valve size. BBO
01-24-2007, 12:27 AM | #4 |
I'm a poor spectator
I'm really surprised you didn't get a zillion responses on this one. I think the most limiting part of your buildup according to what you said is the heads. Personally i'd put aftermarket heads on it. There's a lot of technology out there, why not take advantage of it. 2.02 valves would be the right choice and I would suggest 180cc intake runners because they'll build better lowend torque. On the shortblock end of things, you don't need a whole lot because 350 hp isn't anything crazy. You can run stock cast pistons although it never hurts to have forged. You said you want to make torque so i'd try to go with 9:1 compression. I'm partial to Edelbrock intakes so i'd pick their RPM Air-Gap intake with a 650 Holley double pumper (I like Holleys, I think they are realy easy to fine tune) on top. Roller rockers are definitely worth the expense too. Go with a an Comp Cams Extreme Energy cam like a 268 grind or maybe a 274 grind.
...or buy a crate motor and let them do the thinking for you
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
01-24-2007, 01:53 AM | #5 |
1HP/CID at the flywheel, right? And I'll assume you want the least expensive route to get there
Will deliver somewhere close to 350 FWHP @ 5000 RPM, and > 400 FWTQ 2000-4500 RPM. Basically this is a straight shortblock overhaul upping the CR a bit and then investing in heads and cam. Should be able to get this built for ~$2500 depending on parts condition, what you reuse, etc. Last edited by Billla; 01-24-2007 at 01:53 AM. |
01-24-2007, 03:16 AM | #6 |
Quick way to gain some ponies... Stroke it
Provided the rods are of an acceptable length (depends on the crank), you could swap to a "stroker" crank (383 maybe?) without rebuilding the engine completely. heard of people using a 400 crank with good success... Just flip that puppy over and swap it.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 01-24-2007 at 03:17 AM. |
01-24-2007, 06:34 PM | #7 |
Yah, I was really hoping for more posts than this to, but I'll take what I can get. I'll be running 3.73 gears so that should help a little bit. Do you guys really think that 600cfm would be enough uumph to get me up and going at WOT? Will it keep me out of the secondaries at 65mph?
So If i were to go with the vortec heads which ones should I use, and what else do you need to complete the valvetrain? Otherwise I figure on porting the heads, and redoing them that way. Also any suggestions to get more power would be very welcomed. And I assume that you think that this old engine will be able to handle that much power?? Thanks. Keep it coming.
01-24-2007, 06:40 PM | #8 | |
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
01-24-2007, 07:14 PM | #9 | |
This is an area of debate. I had read an article (it's been so long, I don't remember who or when), that explained that many people put too large of a CFM carb on their motor's. And I can see the though process of "more fuel, more power". Yes the motor burns fuel, but it is a big ol' air pump. So long story short, IMO 600CFM is fine. |
01-24-2007, 07:41 PM | #10 |
Long Fleet Club
This is a good formula you can use to get an idea of what carb to use.
CFM = Engine Size × RPM @ Peak Power ÷ 3456
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
01-24-2007, 07:48 PM | #11 |
Well I would like to make 350 at drive wheels, but probably will only make it to 350 at flywheel, unless anybody has some good suggestions on how to make 350 at wheels. Yah, I've heard that statement before to, but I read a book by David Vizard, and he used a 750 holley on everyone of his builds. But if you guys think that 600 is enough I guess I trust you.
1968 C-10 longbed, 307 V8, 4spd- currently under construction Last edited by chevyc1068; 01-24-2007 at 07:48 PM. |
01-24-2007, 08:16 PM | #12 | |
I think Jtrux and Billa have offered good advice. You can always check the newsstand for Hot Rod, Car Craft, Chevy High Performance, or Super Chevy, they typically have engine builds pretty frequently. 1hp per cubic inch is very doable, especially if you copy a dyno-proven engine exactly, that way you know the parts are matched to work together. |
01-24-2007, 08:22 PM | #13 | |
01-24-2007, 09:29 PM | #14 |
Most common "stroker" for a 350 is the 3.75 stroke for 383 CID. I can't see any way to do this without a rebuild, IMHO. At this build level, 28 CID (383-355) nets ~28 HP and ~28 TQ, and you should figure that a stroker adds about $500-$700 to the price of the build.
If you need to junk the crank, then a stroker gets way more attractive as you have to buy a crank anyway I'm not saying you can't build an el Cheapo stroker - you can; it's done all the time - but they're typically not a very durable engine. |
01-24-2007, 09:45 PM | #15 | |
You don't need to take our word on carb sizing - it's physics The only time you really need to look hard at carb sizing is when you're turning the engine past 5500 - 6000 RPM. It is physically impossible for a normally aspirated 355 to take in more than 600 CFM until you pass 5850 RPM. CFM = ((CI x RPM)/3456) x VE |
01-24-2007, 10:07 PM | #16 |
laying low
Excuse me Murdock. [I would like to keep the fuel economy fairly high since this will be a daily driver, though I want some power to set me back in my seat when a really romp on it]
These two things do not go together well. You can build some good mileage OR good power to set you back in the seat. Which will it be?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
01-24-2007, 10:10 PM | #17 |
I think you can get both, especially in our trucks. The back in the seat thing comes from low-end torque...which is what we build truck engines for generally. A reasonably powerful engine doesn't have to be a gas pig...and shouldn't be - being more efficient.
01-24-2007, 10:56 PM | #18 |
Well I'm talking above 14 or 15 mpg. I don't want to make less than that. I'm not going to stroke it unless for some reason i would have to buy a new crank, then I might consider it.
Does anybody know of a book or site or something that shows different engine builds and their dynos?
01-24-2007, 11:12 PM | #19 |
I am a Referee of life.
Look at Edelbrock.They have package deals on heads,intake,cam and carbs.With a stout shortblock(use the stroker if you have to buy a crank) and the hei and good tuning 350 ought to be easy.I think 14-15 mpg is gonna be tough with 3:73's but maybe....An overdrive would probably get you there though.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-24-2007, 11:49 PM | #20 |
vortec 5.7 heads are definently the best fuel milage/power head for the money. Large valves are not required for low end torque. Strokers cannot be built really cheap because you need to factor in more expensive pistons and never build a 383 without balancing the crank and rods. As for the theory of a 350 not being able to swallow 600 cfm, then why is a qjet 680 to 750 cfm? Volumetric efficency determines the cfm required. To make a true 350hp a 262 comp cam, edelbrock performer rpm intake, vortec heads, and about 650 cfm carb.
01-25-2007, 12:12 AM | #21 | |
Completely agree that VE determines CFM, which is why it's included in the sizing formula. It's not possible to exceed 100% VE with a normally aspirated engine except with very high overlap camshafts and then only at very high RPM..and most street engines see possibly 75-80% VE. So doing the math: CFM = ((CI x RPM)/3456) x VE CFM = ((350 CID x 6000 RPM / 3456) x 100% VE CFM = 607 Q-Jets were built so large because GM wanted *one* carb for every 4bbl application. This is why the primaries are so small and the secondaries so large...it was an "autosizing" carb |
01-25-2007, 12:24 AM | #22 |
I will agree with the math billla. I will clarify myself. A carbs rating according to the flow benches i have tested on are not acurate. Therefore a 600cfm carb does not flow the number. On the dyno i have found a 600 edelbrock is to small for a TRUE 350hp motor unless you start playing with the carb. They tend to fall down a little when wot is called for. This being said, they are good for daily drivers as long as you dont drive it hard. I am just going back to the question WHAT DOES IT TAKE TO PRODUCE 350hp. Also keep in mind that on a dyno hp is corrected to sea level, which means alot if you live in Columus Ohio
01-25-2007, 12:46 AM | #23 |
If you're looking for engine parts or even fully built engines, you might want to check racejunk.com. I havent bought from anybody there yet but they've got performance parts out the wazoo (used and new).
01-25-2007, 12:47 AM | #24 | |
Otherwise, head down to the library and spend some time with CarCraft and Chevy High Performance back-issues. CC is doing some really nice work over the last year or so with a new editor that's really a car guy. CHP does OK...but they do a lot of sitting around watching other people do the work. Popular Hot Rodding Engine Masters is another good one. The problem with some of these is that they're mondo max HP builds :/ |
01-25-2007, 04:47 AM | #25 |
Super Trucker
it can be done, quite easily if you have the right parts and knowlegdge on hand. i'd say find a set of L31 vortecs. with an edelbrock performer or rpm intake. scoggin dickey has a pretty good deal on modified vortec heads. i think for like $1k you get fully machined vortec heads, and matching intake. those heads with the right cam should be able to make some decent horsepower. speed is relative to money, how fast do you wanna spend?
American by birth, Southern by the grace of God. ".. you aint just whistlin' Dixie..." Rebel till I die |
