Junior Member
![]() Join Date: Apr 2006
Would LIKE to buy, but gauging prices...
I really need Shock Relocators for my '70 Chevy. I can get them for about $80, but would like to pay MUCH less. I also would like to know about how much it would be to get either a Posi rear-end or get my open rear-end set up as posi, and still be able to turn a corner without bouncing around everywhere.
located Rogers, Arkansas 72758 |
Active Member
Re: Would LIKE to buy, but gauging prices...
To change your rearend over around $200.00 labor + what ever parts you need.
Posi unit, gears, Axle bearings, carrier bearings, lube, additive, ring & pinion and labor will set you back $1200.00
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
67-72 Addict!
classic performance parts has a deluxe shock kit (4 lowering shocks) including relocators for about $169. Not a bad deal considering shocks are $40 each. I bought my Eaton posi for $280 from Tomsdifferentials.com about 4 years ago.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Junior Member
Thanks for the answers. I have already had the truck lowered, just missing the relocators
