Old 01-24-2007, 10:20 AM   #1
Bullseye54
Rear spring removal problem
I was trying to remove my rear coil & the through bolt on the bottom broke at the head(under trailing arm),looks like it was cracked to start with.Before I started I soaked it with PB Blaster all day but it is major rust welded in the trailing arm.I tried heat & more Blaster with a punch,even tried to use weight of the truck and a floor jack to press it out but no go.Any suggestions before I mess it up?
Bullseye54 is offline   Reply With Quote
Old 01-24-2007, 10:53 AM   #2
cdowns
cdowns's Avatar
Re: Rear spring removal problem
they're a real pain// i've taken the trailing arms off, a good idea to change the front bushings while you're working on them, and have had to use very high heat and a VERY large hammer and punch to break them free
Old 01-24-2007, 10:57 AM   #3
Fenny
Junior Member
I ended up using a air hammer to get my bolts out.
72 GMC 3/4 ton Custom Camper 5.3 ltr 4l60e
72 Chevy Blazer 4x4 327 4spd
70 Olds Cutlass supreme 455 4spd m21
Fenny is offline   Reply With Quote
Old 01-24-2007, 11:21 AM   #4
Mongo
YES_____NO
Mongo's Avatar
call your local repair shop and ask them if they have a press. If they do ask them if you can bring the arm down and have them push it out. I had this done and I think it cost me $5. that was less than the cost of the two cans of blaster I wasted on it......
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 01-24-2007, 12:36 PM   #5
Bullseye54
I was hoping I could avoid pulling the arm,but no such luck.I guess I may as well get ready to pull both.I have a 20 ton press I'll see if that works.Thanks forthe suggestions
cdowns,I live off SR40 in Ormond......Bob
1967 C20 Custom - 396/TH400
1968 GMC short step-350/M21
Old 01-24-2007, 12:51 PM   #6
cdowns
cdowns's Avatar
i'm in ormand beach //beachside south of 40
Old 01-24-2007, 01:52 PM   #7
65-72 chevytoys
65-72 chevytoys's Avatar
Welcome I am just north of you in St. Augustine. THat 20T press should have no problem.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 01-24-2007, 02:29 PM   #8
bryanw1968
bryanw1968's Avatar
I had the exact same problem on my '68. I tried everything but in the end only one thing worked. I heated what was left of the bolt up until it was glowing red and then poured water on it. Nada. I then heated it up red again and poured beer on it and it made this God awful noise and let loose and fell out. I don't think the beer had anything to do with it b.t.w. I was just lazy and didn't feel like getting up to get water
bryanw1968 is offline   Reply With Quote
Old 01-24-2007, 03:40 PM   #9
Mongo
YES_____NO
Mongo's Avatar
thats alcohol abuse!!!
