Bulky
1985 cab going on a 1977 chassis
Any headaches putting an 85 cab, nose and bed on a 1977 chassis? Both are 2 wd long beds. I know 97% of the things bolt up, but just double checking with the people that would really know.... .
I just want to make sure I get everything I need lined up before the swap (Cab mounts, radiator support placement etc....). Thanks |
yeller
Re: 1985 cab going on a 1977 chassis
Get the mounts that go with the cab and you should be all set. I believe you will have to modify your front bumper/frame mounts to run the 85 bumper...Chris (captkaos) has a pic of how he did his, hopefully he'll chime in.
The headlight wiring will also need to be modified to work with the new front clip.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Bulky
Thanks for the tips.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Correct. If you need a pic of the bumper, I can post a link...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Bulky
If you have a pic handy that would be great.
here ya go:
yeller
Beautiful red x's Chris.
Weird, anyone else having that problem. they are linked to my captkaoscustoms.com website, and it isn't down.
http://www.captkaoscustoms.com/images/bumpertrim1.jpg http://www.captkaoscustoms.com/images/modifiedhorns.jpg
Bulky
Pics look good. They are worth a thousand hacksaw blades..
Time to break out the plasma cutter. Thanks again for the help!!! |
yeller
They are working now Chris...for some reason they weren't earlier...and I even copied and pasted the URL to a new window.
That is really weird....
So a cab from an 80's truck should bolt right on to a 70's frame with the mounts from the newer cab?
Core support will mount up no problems too? Looking at a '78 or '79 stepside that is lowered and nice wheels. No engine, tranny and some seious rust issues in the cab. I have an '85 cab and clip in good shape. I am having problems with emissions testing on the 80's trucks but prefer the look of the 80's so maybe this could be my answer.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#13 |
Sb 400 club
bulky you doing the swap on that white truck you got??
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#14 | |
GM changed the size of the body mount holes on the chassis in the 80's. |
#15 |
We got some people saying you need the mounts to match the cab and other say they need to match the frame. Which way is it?
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
#16 |
Allright, allright, I know digging up an old thread, but I didn't feel like creating another one. I am trying to put a '84 cab on a '74 chassis and guess what, neither cab mounts work! The '74 cab mount bolts are to short for the coresuport and the '84 mounts won't fit in the holes on the frame. So more or less it can be done with the help of something to enlarge the holes in the frame.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer Last edited by SanitysBane; 05-11-2007 at 09:37 PM. |
