01-24-2007, 02:30 PM | #1 |
3/4 ton rear question
I been searching for ring & pinion gears for my 69 C20 but havent had any luck. It doesnt appear to be a dana rear, the cover is round and has a 10 bolt cover. Anyone know where i can get 3.73's, id also like to convert to 5x5 axles, just cant find any info on these 3/4 ton rears. Thanks Chad
01-24-2007, 03:35 PM | #2 |
72 C30 Trailer Queen
Re: 3/4 ton rear question
If your cover is round with 10 bolts, you most likely have an Eaton H052.
Available gear ratios were 4.10, 4.57, 5.13 and 6.17(?) 3.90 was available aftermarket. A very desirable option in these rear ends was the NoSpin, or Detroit Locker traction aid.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
01-24-2007, 04:08 PM | #3 |
Pretty tough to find replacement gears or parts for the Eaton's. I finally replaced the whole rear end with an Eaton no spin. Dana's seem to be the one most want.
01-24-2007, 05:26 PM | #4 |
Thanks Allot guys, at least ill head in the right direction. If i deside to swap in a 1/2 ton 5x5 rear ill be sure to post the parts or whole HO52 rear on here.
