PS box / Pitman arm questions
I went to install my new power steering Box (upgrading from manual) over the weekend, and found that my kit, while it included the Box, pitman arm, hoses and pump ($200 for the kit), It didn't have the nut that holds the pitman arm.
does anybody know where i can find this nut? I found it at one of the online companies for $3, but my bookmark seems to have dissappeared, and now i cant remember where it was... Also, when installing the new box, how do you determine that it is centered before putting on the pitman arm (wheels straight forward), and hooking up the steering shaft. Any tips?
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Re: PS box / Pitman arm questions
make sure the wheels are straight then turn you power steering box all the way one way then as you turn it all the way the otherway count how many turns it took then turn it back half that many turn to get the box to the center and then put on the pitman arm. Thats how I did mine.
1985 ![]() |
67 chevy SWB Fleetside
I bought one of the pitman arm nuts from Totally Stainless.
You can have one of my nuts. My wife makes sure I don't use them anyway.
-Scott- |
Questionable
I just pulled the pitman arm nut and lockwasher off my old non-power setup and it worked with the new one. Polished it up, sprayed it and screwed it back on.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Gotta love the easy fix!
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
#7 | ||
![]() ![]() Quote:
Thanks ![]()
#8 | |
TMI ![]()
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#9 | |
Questionable
I originally had manual steering - pulled that, installed power. Nut and lockwasher were fine. Curious to know if your experience is the same.
