Old 01-24-2007, 04:19 PM   #1
Greubin
Greubin's Avatar
Column Shifter rattling
Anyone had a auto column shifter rattle? Mine is driving me crazy, sounds like the inner rod that runs the length of the column is rattling. The rattle goes away if I rest my hand on the shifter.
Is there an easy fix?
___________
Greubin
'71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI
Greubin is offline   Reply With Quote
Old 01-24-2007, 10:48 PM   #2
ghetto_superman
ghetto_superman's Avatar
Re: Column Shifter rattling
if theres a spring down on the end of the column, maybe check to see if that has tension on it.. I had one that had a loose spring, and it didnt rattle like you say, but it was sloppy, and after fiddling with it for way too long (not the right tools) i got the spring so that it held tension really tight against the bearing and it helped out a lot. This probably wont help you much, but Its worth a shot anyway.
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
