Old 08-25-2002, 10:32 PM   #1
BUXMAN66
go bucks!
tranny cooler lines install?
anyone tried to put some new lines in their truck w/engine in already?(hoses,etc..) what a bitc@ of a time!!kinda ruins the whole idea of pre-bent lines,eh? and they're s/s to boot!!anyone got any bright idea's?
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 08-26-2002, 02:51 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
i went the easy route and cut the bad spots out and reconnected the lines with fuel hose....just till i decide to rebuild the engine and then i'm putting in new lines.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-26-2002, 07:27 AM   #3
JimKshortstep4x4
Smile
That is the way we install the lines. They will go in from the front. It is a little tricky and some times you have to deflect them a little
to wiggle them into place. There is no way to describe how it is done other than to snake the lines in. I usually put the lower one in first and save the upper for last, (the upper being longer is more difficult).
Jim
Old 08-27-2002, 01:22 PM   #4
BUXMAN66
go bucks!
i decided to yank out the new cooler lines that i installed this past wkend. just looks kinda junky in a nice clean engine compartment to have the lines all twisted 'round in the front of your engine for everyone to see! found a cool little set-up w/ jegs it is part #771-1003.goes on the inside of your frame rail,and will install w/high pressure rubber hose. 1.5"x 2"x24"long.the jr.cooler is the same except 17"long.and no, i ain't towing w/this truck!
