Old 01-24-2007, 09:48 PM   #1
00droptopSS
2.5/4 on 20's
00droptopSS's Avatar
Frame Help
I have a SWB 62 truck that I'm starting a quick restoration on. I also have a 1985 Chevy LWB parts truck for it's front suspension and a nice 63 big window cab, media blasted, and metal work complete.
Now for my question. I want to use my 63 cab and ditch the 60-62 suspension. Am I better off finding a 63-66 frame and add the suspension? Or will a 67-72 frame work with a 63 Cab? Is it possible to use a 73 and up frame with the 63 Cab?
I don't mind modifying the frame some to get the cab to fit. I'm just looking for the quickest and most cost effective way to get this done.
Thanks for the help.
62 C/10 SWB. Currently in ground up resto. Big back window cab, V8, auto. My wife's grandfather's truck.
1965 Mustang Vert - Shelby Clone
2005 Dodge SRT-10
My Old 72 SWB
00droptopSS is offline   Reply With Quote
Old 01-25-2007, 12:02 AM   #2
62 short step
62 short step's Avatar
Re: Frame Help
I Think The 67-72 Frame Would Be Better.you Will Definitly Have To Relocate Some Body Mounts, But That Shoulnt Be To Difficult.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-25-2007, 12:11 AM   #3
00droptopSS
2.5/4 on 20's
Re: Frame Help
I wonder how many, if not all, of the mounts I would have to relocate?
What part of Louisiana are you from?
2005 Dodge SRT-10
My Old 72 SWB
Old 01-25-2007, 12:17 AM   #4
62 short step
Re: Frame Help
I think just the cab mounts, but not 100% positive. I'm in Central City right outside Baton Rouge.
1965 c-10
86 chevy c/k 20
Old 01-25-2007, 02:51 AM   #5
thekid54
Re: Frame Help
If you put the 63 cab on the 62 frame you will have to change the front cab mounts, rear ones should be the same. I'm doing the exact opposite right now (62 cab on a 63 frame). I think you would be better off finding a 63 or later frame IMHO.
thekid54 is offline   Reply With Quote
Old 01-25-2007, 09:45 AM   #6
darklord
darklord's Avatar
Re: Frame Help
??? kid, he's talking about 62 cab on 67-72 frame. And yes it can be done but I also do not know wich mounts need to be changed.
darklord is offline   Reply With Quote
Old 01-25-2007, 10:10 AM   #7
thekid54
Re: Frame Help
darklord, are you sure about that?:
From 00droptopSS's post:
"Now for my question. I want to use my 63 cab and ditch the 60-62 suspension. Am I better off finding a 63-66 frame and add the suspension? Or will a 67-72 frame work with a 63 Cab? Is it possible to use a 73 and up frame with the 63 Cab?"
Old 01-27-2007, 06:30 PM   #8
stepside66
stepside66's Avatar
Re: Frame Help
I am kinda in the same boat but I am probably going to cut the tranny crossmember off and take the front suspension off and bolt up 73 + parts and go from there
stepside66 is offline   Reply With Quote
Old 01-27-2007, 09:08 PM   #9
00droptopSS
2.5/4 on 20's
Re: Frame Help
Well, I've decided to use the 62 frame and just make the adjustments that are needed.
I tore apart the truck today and found more rust than I really expected. I'm going to have to repair the frame before I send it to be powder coated.
2005 Dodge SRT-10
My Old 72 SWB
Old 02-02-2007, 08:20 PM   #10
kris's66lwb
resident wrencher
Re: Frame Help
i have seen a 66 on a 85 frame that fit pretty good but it will take a little bit of work but the bouns of 73 and newer frame is the abillity for lift kits
kris's66lwb is offline   Reply With Quote
