Old 01-24-2007, 10:18 PM   #1
myersjeremy
myersjeremy's Avatar
Stuck plug in the head
For whatever reason I can not break the plug loose in the head so I can install the temperature sensor. I have pried and pried on it and now have rounded out the hole for the ratchet. Any ideas on getting it out? Thanks for the input......
myersjeremy is offline   Reply With Quote
Old 01-24-2007, 10:42 PM   #2
HotRod73
HotRod73's Avatar
Re: Stuck plug in the head
spray some PB Blaster on it, let it set a little bit then try, or use some marvels mystery oil... this has happend to me plenty of times on old motorbikes, these always seem to do the trick =)
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
