How does it work? Idle solenoid...
Am having a little trouble understand how the idle solenoid operates... it does not appear on any of the wiring diagrams I have or can I find a book that explains it operation... (I have the 1970 service manual and the factory assembly manual) ... it is a red wire.
How does it work? ... once the key is turned on does it stay energized continuously? I understand how to adjust it ... just no sure why it is there... can someone make me smarter... thanks Vic 1970 |
idle solenoid usually is energized only when a/c compressor clutch is turned on to keep engine idle from decreasing,
is adjustable by turning the shaft of the solenoid that contacts the carb linkage |
My truck did not have air. But it had a idle solenoid, as far as your ?, yes when u turn on key it pops up when key is off it goes to rest postion this is so the butterflys close all the way to avoid dieseling or run on.
72 Cheyenne Stepside 357/TH350 3.07 Posi 379HP@5500 412FT#@4000 96 1500 Work Truck 88 Chevy Van 3/4 97 Tahoe 8.5 Lift (Sons) 00 1500 LT 4x4 (Sons) 98 Ford Cobra (Wifes Car) |
CCRider
It is a anti-deseling solenoid, it shoud push out any time the key is on. You set your idle speed with the "bolt" end of the solenoid, and have the idle screw on the carb set completely closed. Now when you turn the key off the carb closes completely, no deseling.
http://www.autotune.com/cprotest/cpc8f.html
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS Last edited by tom hand; 08-26-2002 at 09:16 AM. |
Thanks..understand it now... appreciate it...
Vic 1970 |
