Old 08-25-2002, 10:47 PM   #1
BUXMAN66
go bucks!
sway bar install
was thinkin' 'bout installing one ,got to lookin' under mine and noticed that i didn't have one. i unnerstand how it attaches to the frame,how about how it attaches to the lower control arm.i got a MANUAL!brake drum setup if that helps any.did the factory 6 banger trucks not come w/a factory sway bar?thanks all.
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 08-25-2002, 10:58 PM   #2
Gee_Emm
It attaches to the front control arms with "u" shaped clamps with a rubber or poly bushing inside, they mount on they flat part in front of the spring.
Gee_Emm is offline   Reply With Quote
Old 08-27-2002, 01:33 AM   #3
BUXMAN66
go bucks!
thanks gee em!think i'll look into it on that!
Old 08-27-2002, 01:41 AM   #4
slam33
slam33's Avatar
You arms should have the holes already drilled
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-27-2002, 08:00 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
The best thing to do is to go to the junkyard and find a truck with one on it and you'll see exactly how it mounts. (you'll need it anyway so grab it while your there) The brackets are riveted on so you will need to cut them off or have them cut off. New ones are available to avoid that step. Just use bolts to re-install.
The trucks up to around '87 (correct?) are all the same and very easy to find. Check the 2 wheel drive 3/4-1 ton trucks.
Alot of these trucks didn't have the sway bar but no harm in adding one. My '69 stepside doesn't have one. (someday it will)
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-27-2002, 01:10 PM   #6
BUXMAN66
go bucks!
thanks guys!i'll check a local yard for one. just did'nt remember how it mounted to the lower control arm.i'll double ck. to see if i have the drilled holes already in lwr.cntl. arms.i did see the holes in the frame in the proper location,though.thanks again!!
