Old 01-25-2007, 02:02 AM   #1
T_Ruxx
power brakes upgrade for a 74 1/2 ton
I'd like to add a booster to the master cyl. , is there a how to somewhere in here, I did a search on the board , didn't turn up much. anyone done this upgrade? thanks for the info. Greg
T_Ruxx is offline   Reply With Quote
Old 01-25-2007, 05:07 PM   #2
tkeduk8r
tkeduk8r's Avatar
Re: power brakes upgrade for a 74 1/2 ton
pretty easy upgrade... but you need the booster (duh), brackets, and preferrably a new master cylinder for power brakes. When I did mine I got the pedal and rod asembly out of the same donor truck to make everything work. If you dont you will have to adjust or replace (cant remember) the rod because the manual brake rods and power brake rods are different sizes... someone on here will know for sure...
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
