Old 01-25-2007, 10:42 AM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
? Installing 90's Cheyenne seat in 67-72 ?
I haven't realy looked at it yet but is this a "bolt in" type of deal or will I need to drill holes? Ad brackets?
I just picked up a 60/40 bench and want to install it this weekend.
Thanks in advance
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 01-25-2007, 11:40 AM   #2
454_72_4X4
454_72_4X4's Avatar
Re: ? Installing 90's Cheyenne seat in 67-72 ?
The 60/40 won't be a complete bolt in but it shouldn't be to hard. The inner bracket on the 60 part of the seat will be the biggest headache. You might have to build some spacers, or worst case, you might have to shorten the bracke on the seat. Depending on which truck has the taller trans tunnel.
The outside brackets should be a "just drill the holes" deal.
I have a 88-94 bench seat in my 72. IIRC I just drilled 2 new holes for it.
Post up some pics when ya do your 60/40.
I've got a 99 60/40 spotted I'd like to swap into my 72.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-25-2007, 11:49 AM   #3
Zumo
Hot Rods For Life
Zumo's Avatar
That's waht I am curious about. The shorter brack on the "60" seat. I wonder if I could get another bracket like the tall one and get it to fit.
Andy
Old 01-25-2007, 11:56 AM   #4
454_72_4X4
454_72_4X4's Avatar
I think the taller bracket would bolt onto the seat but then it'd probably be to tall
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-25-2007, 11:58 AM   #5
454_72_4X4
454_72_4X4's Avatar
Does your 68 have a "high hump" or "low hump" trans tunnel?
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-25-2007, 12:09 PM   #6
whatnow123
whatnow123's Avatar
If you could take a couple of pictures and do a write up about the process that would be awesome as I just picked up some 04 Silverado Seats. Mine are 40/20/40 with a center arm rest. The middle section fits over the hump perfect but I'm wondering about the rear brackets on the buckets. I tossed mine in there just to check fit (I'm pretty far from installing them currently) and seems like it's not going to be too much trouble.
whatnow123 is offline   Reply With Quote
Old 01-25-2007, 12:46 PM   #7
Zumo
Hot Rods For Life
Zumo's Avatar
Low hump right? Since it 2wd.
I will try to get some pics of my efforts as well.
Andy
Old 01-25-2007, 03:57 PM   #8
rodstored-72
chevy truck fan
rodstored-72's Avatar
i too would love to see a write up on this as well.. i am currently looking to do the same & was wanting to know what i would be looking at in the case of mods needed to make it work...
thanks!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 01-25-2007, 03:58 PM   #9
jimmydean
jimmydean's Avatar
I used 4 washers for the front bolt of the 60 seat and my seat sits about perfect. Without it, it looked ok, but was just a little lower than the other seat.
jimmydean is offline   Reply With Quote
Old 01-25-2007, 04:55 PM   #10
Zumo
Hot Rods For Life
Zumo's Avatar
Thanks Jimmy, I'll be somewhat prepaired.
Andy
