Old 01-25-2007, 12:21 PM   #1
N2GMTrux
N2GMTrux's Avatar
Gearbox "lock to lock 3 turns"
Does anyone know what year model (71 to 87) Chevy truck or van powersteering gearbox had three turns lock to lock that would fit my 71 C-10.
N2GMTrux is offline   Reply With Quote
Old 01-25-2007, 12:51 PM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: Gearbox "lock to lock 3 turns"
Mine is from a '77.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-25-2007, 01:07 PM   #3
N2GMTrux
N2GMTrux's Avatar
I've been looking at the boneyards and all the trucks I've found are missing the P/S box. But I did locate a 78 Chevy van which I bought my tilt column from. Will the van P/S box work or is it strictly just a truck gearbox.
Old 01-25-2007, 02:24 PM   #4
Green Machine
Green Machine's Avatar
Don't know if this helps but we replaced the leaky PS gear on our 71 C20 with a unit from a 78 c10, the 78 unit does require less turning lock to lock than the original did.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-25-2007, 03:00 PM   #5
N2GMTrux
N2GMTrux's Avatar
Thanks,,,,,I,ll keep checking the salvage yards until I find a 77 or 78 with three turns lock to lock.
Old 01-25-2007, 03:04 PM   #6
454_72_4X4
454_72_4X4's Avatar
I'm not famaliar with 2wd trucks or vans but the one determining factor if the van box will work on your truck would be if it mounts on the same side of the frame. I think 2wd trucks mount on the inside of the frame? 4x4's mount on the outside of the frame. Van boxes mount??? Dunno!
You'll need to swap out your pitman arm with the one on the van box.
Other options would be S-10 and cars. Alot of them use the same Saginaw steering box as the older trucks but they might have different internal stops and the newer ones will have different style fittings for the hoses.
I just put a Monte Carlo box on my wife's 95 S-10 Blazer last night, and I have one off of an IROC Camaro on my S-10. The Camaro box on my S-10 steers great but it won'tlet it turn as short as the original box would.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-25-2007, 03:22 PM   #7
N2GMTrux
N2GMTrux's Avatar
Thanks for the info! I'll have to really look into the mounting of the box. Hopefully I can find a box soon,,,,,,It sure is hard to shift gears "3spd" on the column and make a sharp turn with no power steering.
Old 01-25-2007, 03:51 PM   #8
Green Machine
Get the rag joint with the box, the shaft size changed some year in there, the old rag joint won't work.
Old 01-26-2007, 01:02 AM   #9
dingo_dan_22
dingo_dan_22's Avatar
I threw one on from a 74' . Bolted right up and was the right length with the right rag joint and pitman arm. The original should have the same internals up to 76'. Reman part #'s change in 77'.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop
dingo_dan_22 is offline   Reply With Quote
Old 01-26-2007, 06:06 AM   #10
arkracing
Weekend Warrior
I don't think a Van box will work - input shaft has a differant angle than a regular truck I believe, but don't quote me on that.
If you don't have power steering, why not just get a P.S. box from a '73-87 truck with the Pump, Lines, and pulley set up. You will probably have to change your waterpump to the later long style to configure with the later pump/pulleys. Get the Alt. Braket as well - as that will change.
Not as hard as it sounds and then you don't have to worry about strong arming it while worrying about shifting
Just a thought
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-26-2007, 02:55 PM   #11
454_72_4X4
454_72_4X4's Avatar
Input angle would be different on a van but only because the entire box is tilted.
The long waterpump style brackets and pump will definately be easier to find.
You could get the pump and brackets off of a van also, (as long as it's smallblock powered), but the lines probably won't work.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-27-2007, 08:08 PM   #12
N2GMTrux
N2GMTrux's Avatar
Talking Re: Gearbox "lock to lock 3 turns"
Thanks for all the info,,,,,the van P/S ox will not work due to the angled connection. But I did find a P/S box from a 1977 C-10 with three turns lock to lock. Thanks for all the info!!!
