Old 01-25-2007, 08:12 PM   #1
Joe Gribben
Joe Gribben's Avatar
Question big block in a 2wd 67
need help i have a buddy that is building a 67 small back window,he has a 502bb chevyhe is wanting to drop in what is he going to need for motor mounts.67 to68 framesare differant or not
Joe Gribben is offline   Reply With Quote
Old 01-25-2007, 08:27 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: big block in a 2wd 67
67 & 68 are the same- he will need to buy the big block towers and that should be it, however it would be much easier to let me haul off that big old motor so he won't have to worry about it
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-25-2007, 08:53 PM   #3
sixtysevengmc
village idiot
sixtysevengmc's Avatar
I'm not 100% certain,but I think their different.top of the frame rail is wider on a 67 than 68-72
sixtysevengmc is offline   Reply With Quote
Old 01-25-2007, 09:59 PM   #4
kevncar
Active Member
kevncar's Avatar
Yeah, the 67 frames don't have the top flange of the frame narrowed like the 68s and up. See my build thread, and you'll see pics of me trying to get my motor stands bolt holes to line up.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 01-25-2007, 10:25 PM   #5
corn
Why not just bolt it in? If he is running headers it should be no big deal anyway. Ive had a small block & a big block bolted in my truck with big towers. Have done it both ways with small block towers too in a later truck too...
corn is offline   Reply With Quote
Old 01-26-2007, 12:48 AM   #6
Robznob11
Robznob11's Avatar
sb and big block towers will work , heck even 73 and up towers will work, nothing there that a blue tip wrence or saws all cant handle....just don't be skeeeered.....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 01-26-2007, 07:55 PM   #7
bagged91
Out draggin'
bagged91's Avatar
Been helping a friend of mine do the same thing to his 67 sw shortbed. http://67-72chevytrucks.com/vboard/s...d.php?t=223504 The tops of the framerails needed to be cut back a little here & a lot there. 68-71 BB stands are "clearanced" from the factory with the dimple on the top for the exhaust manifold. The 72 BB stands are altogether different. 73+ stands are the same for BB or SB. Tell him to save himself a lot of work and look for a set of 72 BB frame stands(insert flame here). The 68-71 BB stands are more readily available but the motor mounts are A LOT more money. I don't have any personal experience with the 73+ stands but I have heard that they go in with a drill and will allow you to run the later clamshell style mounts as the 72 BB stands. My friend attempted to use(albeit DID use) SBC stands and had a nightmare trying to get headers to fit. After a lot of cutting, welding, cussing and crying(not to mention pulling the motor quite a few times!!!), he got them to work(but he did put a stout chain on it too just incase the sh!t hit the fan. He also is running the later long waterpump and has issue's putting a belt on the crank pulley.
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 01-26-2007, 09:49 PM   #8
corn
I went the cheap route when I replaced the motor mounts on my 69. I bought 6cyl mounts @$9 & ground a little of the side material off. I did have to grind a little of the extra material off the sides to clear a spot of casting on the block but it saved me big bucks...
