01-26-2007, 09:53 PM | #1 |
69 Brake lights
Thank you all for having such a great forum. I have only had my truck for two weeks, but I already have fallen in love with this site. I have recently purchased a 69 c10. I have front and rear lights, all turn signals but I can't seem to get the brake lights working. My father in-law said I should have a switch that is pushed when the brake pedal is pressed, but the only switch I find at all is located just off the master cylinder. Any help would be greatly appreciated.
01-26-2007, 11:29 PM | #2 |
Re: 69 Brake lights
The switch is under the dash.
Read this thread and grab the wiring diagrams in it for yourself: http://67-72chevytrucks.com/vboard/s...wiring+diagram
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... Last edited by 69TowRig; 01-26-2007 at 11:31 PM. |
01-26-2007, 11:36 PM | #3 |
Re: 69 Brake lights
the swith is up behind the brake petal under the dash. it look like a bbq start switch with two wire termanals
01-27-2007, 10:36 AM | #4 |
Re: 69 Brake lights
Thanks. As soon as it warms up today I plan on working a little. THe wiring diagram is great.
01-27-2007, 12:56 PM | #5 |
Active Member
Re: 69 Brake lights
Switch pic looking up under dash, it has the orange wire on it.
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". Last edited by GMCMAX; 01-27-2007 at 01:00 PM. |
01-27-2007, 04:39 PM | #6 |
Re: 69 Brake lights
I found the switch thanks for all of the help. It was much higher than I figured. I thought it was a switch that was pushed when in reality it is released. It isn't the culprit though it works so I'm on to rule out the next steps. Thanks again!!!
01-27-2007, 05:07 PM | #7 |
its all about the +6 inches
Re: 69 Brake lights
do the turn signals work?
01-27-2007, 05:08 PM | #8 |
I am a Referee of life.
Re: 69 Brake lights
coach, the next step is grounds.It's a mantra on these trucks when you have an electrical problem "Check the grounds".You should also check to see that the bulbs are correct.The connector plug under the bed should be good since you have the other lights but there may be a worn or broken spot in the wire,especially where it runs thru the frame(should be a rubber grommet btu it's 40 years old if it's still there.
BTW did I mention that about 50% of the time the problem is with the grounds"Check the grounds".
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-27-2007, 09:47 PM | #9 |
Re: 69 Brake lights
that's why I asked about the turn signals. If they light up, then the grounds are good, and it also removes all the wires from the troubleshooting steps.
01-27-2007, 11:22 PM | #10 |
Re: 69 Brake lights
Jeezzzzeee LM You're smart.I knew that just had never reasoned it out that way.Or if I had seen you post like that didn't remember.
01-29-2007, 10:17 PM | #11 |
Re: 69 Brake lights
The turn signals are fine. It seems that the previous owner did alittle rewiring, and the wires for the brakes have been removed. I hope to get the replaced this weekend. I really appreciate all of your knowledge. This site is a lifesaver. Thanks again!!
