Old 01-26-2007, 10:09 PM   #1
chipflyer
chipflyer's Avatar
72 paint code question
I am trying to come up with the paint code for a 72 truck that has a white roof with the rest of the truck being black. Can anyone help?
Thank you,
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 01-26-2007, 11:46 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: 72 paint code question
heres the only site you need just click on the correct spots.
the code should be on the glove box door
http://www.tcpglobal.com/autocolorlibrary/
rage'nrat638 is offline   Reply With Quote
Old 01-27-2007, 12:10 AM   #3
chipflyer
chipflyer's Avatar
Thanks,
Its not listed on Autobodys site and I don't have the glovebox door.
Can anyone else help?
thanks
Old 01-27-2007, 12:51 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The two tone code would be 460. The black is code 9000 and the white is code 2185. These are PPG codes...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-27-2007, 02:06 AM   #5
chipflyer
chipflyer's Avatar
Thank you Chuck, I appreciate it!
Jeff
Old 01-27-2007, 09:03 PM   #6
Rod
The glove box code would be 530, that being black with a white roof.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-27-2007, 09:28 PM   #7
chipflyer
chipflyer's Avatar
I appreciate it Rod, I would assume chucks code would be white/black/white or white band down the sides?
Thank you,
Jeff
Old 01-28-2007, 12:02 AM   #8
Rod
Nope, Chucks codes have nothing to do with the GM RPO codes. Which is what your after for the spid.
