Old 01-26-2007, 10:14 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
numbers on heads
Trying to figure out what heads the PO put on my engine, trying to decide if i should go with vortec instead.
heres the numbers on the driver side head:
in front near grill - GM 5
in rear near firewall - 3932441 D 150
can anyone tell me what they are?
tia
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 01-26-2007, 10:21 PM   #2
larry may
Re: numbers on heads
76cc chambers 350 engine 69-70 this is according to MORTEC. The D 15 0is the date of being cast Looks like April 15th 1970 . Just a SWAG on my part. Larry
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 01-26-2007, 10:29 PM   #3
Boise69
The Hammer Man
Boise69's Avatar
ok, so what do i have here? stock GM heads from 1970, with 76cc chambers? what is 76cc telling me? is that any good? can the be better? or just switch to the vortec and move on.? and what does SWAG mean
1997 MBZ E420
Old 01-26-2007, 10:33 PM   #4
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
441's are a decent performance head when worked right. They were on 275hp police motors aswell.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 01-26-2007, 10:37 PM   #5
Boise69
The Hammer Man
Boise69's Avatar
how would one 'work them' right? what would i have the machine shop do? i'm not into radical just good performance and i'd like 350 hp.. this is a daily driver and a wanna be tennessee mountain runner.
1997 MBZ E420
Old 01-26-2007, 10:43 PM   #6
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
I'd have them ported and polished, 2.02 and 1.60 valves, a small cam, good 4bbl intake, good sized carb (650cfm), will get you 350hp easily.
Everyone rides old iron heads into the ground, but I ran low 10's on a set from the mid 60's.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 01-26-2007, 11:14 PM   #7
larry may
1badss has you covered. A swag is A scientific wildA$$ guess
Old 01-26-2007, 11:17 PM   #8
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Not to dissagree with 1BadSS I use the stock steel heads on a lot of builds myself, But it depends on what the person is after budget and performance taken into account. 441 are the run of the mill truck head. IMO its not cost effective to port polish and install 2.02 1.60 valves in these. Taken into account what can be had for less money and better performance right out of the box. I don't want to step on anyones toes just my .02 good luck with the build
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 01-26-2007, 11:27 PM   #9
BarryB
BarryB's Avatar
with racingjason, By the time you spend all the money to work them right. You could have bought a new set of performance heads. I know, I have a set of heads I had worked. By the time I had all the machine work done and hours spent porting and polishing my old 041's. I could have had a good set of world product heads.
also like racinjason. I am not trying to step on anybodies toes. just telling you my experience.
If you decide to use Vortec heads, Keep in mind you will also need to get a Vortec intake.
I would weigh my odds.
BarryB is offline   Reply With Quote
Old 01-26-2007, 11:52 PM   #10
cooters
i agree it is to expensive to fix up old heads for the cost of better ones. | have found that light port work to remove casting flash and sharp corners and keeping 194 150 valves is better for low end torque, and is pretty cheap
cooters is offline   Reply With Quote
Old 01-27-2007, 12:11 AM   #11
Boise69
The Hammer Man
Boise69's Avatar
Currently It has a EB RPM Air Gap intake. An EB 700cfm carb. energizer Crane Cam and 3 years new. i'd rather not change any of that, my question is, did my PO know what he was doing when he used these heads with the rest of the set up and if so, should i just have the heads 'mildly worked', would this produce 350hp ?
Old 01-27-2007, 12:18 AM   #12
RACINJASON22
GEARHEAD
IMO heads mildly worked and depending soley on the exact cam's specs you should be close to your mark. I think you would have a nice daily driver
