01-27-2007, 02:57 AM | #1 |
How can I remove this rust?
This piece is the radiator support on the bottom I have tried different size wirewheels and I cant get into the corners to remove the rest. Any suggestions?
Pics say it all.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-27-2007, 03:03 AM | #2 |
Re: How can I remove this rust?
Small sand blaster or if you are using POR15 then that is just the right amount of grip the paint likes!
Kevin LFD Inc. |
01-27-2007, 03:05 AM | #3 |
No sandblaster here I dont have por15 but eastwoods rust encapsulator is on its way. Wonder if rust mort will do the trick to?
01-27-2007, 03:28 AM | #4 |
Muratic acid. Comes in gallon jugs and is about $5 buck a gallon. You get it at any hardware or home center. You will need a respirator with this stuff or it will knock you on your a$$. Use a chip brush to brush it on and then cover with paper towels and keep it wet with acid. Should take a couple hours to get it nice and clean. Be sure not to get it on concrete, it eats it up. Oh here is something else. I use a 5 gallon buck with 2 gallons of acid to 2 gallons water to dip small parts. Quick easy and cheap. Takes all rust and paint off quickly.
01-27-2007, 07:44 AM | #5 |
Rust Encapsulator is the way to go......
1997 GMC Sierra Ext 1965 Mustang |
01-27-2007, 08:56 AM | #6 |
My entire frame (heck so far most of the body too) is done in it. I really like the stuff.
01-27-2007, 11:35 AM | #7 | |||
Union Electrician
I used the eastwoods too and that is clean enough for it right now. I used the two part converter then rust encapsulator and their epoxy chassis paint on top of that. Works great and looks great too
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
01-27-2007, 11:37 AM | #8 | ||||
Union Electrician
Doesn't water neutralize muratic acid?
01-27-2007, 11:43 AM | #9 |
In large amounts it does. But a 25% acid mix or more works fine. I dilloute it with water for light rust but even a 50/50 mix removed that nice scale rust off of my front a arms in a day! Use it straight and it will take heavy scale rust off in about 1 hour. Oh yah, you will also need chemical gloves for this stuff to or it will burn you bad.
01-27-2007, 11:48 AM | #10 | |||
Union Electrician
I just remembered cleaning a pool at a retirement home when I was in high school and used muratic and just washed it off.
Thank you for clearing that up and alos thank for the tip I'm sure I will use that advise in the future
01-27-2007, 12:01 PM | #11 | |
Spanked once
01-27-2007, 12:04 PM | #12 |
Yah outside use only with that stuff. I have tried to find the phosphoric acid around here but it is pretty hard to find when I look for it.
01-27-2007, 12:05 PM | #13 |
Sierra Grande Club
What about Naval jelly?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-27-2007, 12:07 PM | #14 |
To slow! Naval jelly compared to muratic acid is like comparing a 3cyl geo to a blown big block with nitrous. That would be the best way to explain it.
01-27-2007, 12:07 PM | #15 |
Picklex, I think its one of the best.
67- 72 Parts collecter |
01-27-2007, 01:06 PM | #16 |
Rolled on Paint Club
A small twisted wire cup brush on a drill is good to get into those small places. Also a small straight wire brush in a die grinder at high speed works. The high speed makes the wires spread out and work better. Wear safety glasses.
Picklex 20 is excellent. I did my whole frame with it before painting. Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
01-27-2007, 01:22 PM | #17 |
Muriatic acid can be purchased at Lowe's or Home Depot ... or at least around here they can.
Brick masons use it to "clean" the extra mortar off of bricks once they are finished laying the brick. |
01-27-2007, 01:25 PM | #18 |
Harbor Freight has a small handheld sandblaster for about $15 and then you just need some blasting media. I bought some play sand at HomeDepot to rough up some chrome headlight bezels for paint. Needed to be sifted though to get the pebbles out. I know sand isn't a good media but it worked.
01-27-2007, 02:54 PM | #19 |
A good place to find sand blasting sand is small hardware stores such as mom and pop stores or farm supply stores. I get my sand at a local mom and pop hardware store for like $6 for a 50# bag.
01-27-2007, 03:48 PM | #20 |
70ChevyChris I checked out harbors web site but I cant find it. Do you have their part number for it?
01-27-2007, 08:52 PM | #21 |
If you have a compressor the small handheld blasters (search for Speed Blaster) are great for that type of clean up. After you blast apply some Picklex 20 and your ready for prime and paint.
72 SWB parts and pieces Oklahoma |
01-27-2007, 08:55 PM | #22 |
That ain`t rust.That`s oxidation.
01-27-2007, 09:00 PM | #23 |
Get a piece of sandpaper in there, scuff it up, rust encapsulator, done.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-27-2007, 11:30 PM | #24 |
Muriatic is nutralized by big amounts of water, but just by itself it can remove heavy stuff. i never seen someone use it on rust and yes you will need some safety equipment with the acid and have water nearby because if it got on your skin it will burn, i know i use it on pool. i also seen por 15 and i works and looks good but i sand blasted part of a frame and it just looks and remove everything beter
01-28-2007, 12:47 AM | #25 |
Chap, I had learned it from my aunt, she has a pool but fills with well water and it had a high iron content, brown rusty colored water, and she added the muratic acid to clean it up and so I began playing with the mix to get the right amount of power.
