Are these worth buying?
Wanting to know if anyone has purchased these mounts from POL? Ill be running a big block with 2" headers so Ill need all the clearance I can get. Also I have seen that when running a big block the trans crossmember is supposed to be raised 3/8" more than with a small block but from the looks of this pic the trans crossmember only bolts to the frame in one position. Does anyone have any help for the new guy? Sorry couldn't get the tranny mount pic on here file was too big. By the way does anyone know how I can make a picture file size smaller.
Re: Are these worth buying?
i have them but i have not installed them so i am no help. i will keep you posted though if you would like.
#3 | |
otherwise, right click on the picture, chose "Send to" then "email", and windows will ask if you want to resize the picture. select "yes" and it will open a new message in outlook with the resized image attached. cut the attachment and paste it wherever you want to save it, and you have a resized picture in a matter of 4 clicks of your mouse.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Where do those motor mounts come from?
![]() Midwest All Truck Nationals, Riverside, MO - 2008 - 2015 |
These mounts are from POL (Performance OnLine). I purchased the kit with the Trans Member, Front Shock Relocators, Motor Perches, and mounts. I was pleased with the service but i have not installed anything due to the weather.
#6 | |
member #16
![]() Join Date: Dec 1999
Here I found a thread using those mounts on a 67 http://67-72chevytrucks.com/vboard/s...d.php?t=193961 http://www.irfanview.com/
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 01-27-2007 at 07:55 PM. |
