Seasonal Poster
Have about $1000 to spend on truck, need ideas
Ok i just ran into some extra money and i want to spend some on the ol truck, but im not sure what to do...i was thinking maybe a new carb/manifold setup, but i dont know , i just have a basically stock engine, except for dual exhaust and hei ignition...i kinda want more power...i guess check out my website to see what i have already and then gimmie some suggestions. thanks
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
Old Skool Club
![]() Join Date: Jun 2001
I asked this question once, when looking for ideas (dream) for how to spend $10K.
For $1K, and you're looking for more performance, as I read your post, I'd consider the following: 1. New cam - consider an Extreme Energy grind from Comp Cams. They're made for trucks. Replace your rockers and lifters, too. 2. New intake - I have an Edlebrock Performer. 3. New carb - I'm running an Edelbrock 1901 (Q-Jet). 4. Headers - if you don't already have them. 5. K&N Filter 6. Wiring harnesses - under the hood....one for the engine and the other for the lighting. If you're doing the work yourself, you'll be pretty close to having spend your stash.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Listening since '86
Some pretty nice looking trucks on your website, I recognize the buildings in the background too!! The black truck photos are on Dayton Rd by the Army Surplus store, right?
The orange truck is pretty sweet too!
2007 Saturn Aura - hey it WAS a GM product |
Seasonal Poster
yeah man!!
it was at the Boyd Autobody show....are you from kelowna??
Seasonal Poster
Thanks ChevLoRay
Those are some good ideas...i was thinking i will try to go with the cam idea...wouldnt mind a bit more aggressive idle, and then the intake too...the only thing is im a little scared to install a cam..it would all be in my driveway...is this doable in the driveway?
you could get new heads. Depending on what kind you get. My first choice would be a cam though.
Build Thread |
Old Skool Club
A driveway can be just like a garage without walls and a roof. Same grease. Same heat and cold weather. Same rain. Just no wat to get away from it. I suspect that many engines have been modified in the driveways of the owners and builders. A garage is nice, but the truck doesn't know it even exists.
Cleanliness is the key, whereever you decide to do the job. Whether it's an intake or a set of lifters, or a camshaft. Just remember to keep everything clean.
